I want to run ethercat and a mesa
- Kieran
- Thank you received: 8
25 Mar 2025 21:31 #324923
by Kieran
I want to run ethercat and a mesa was created by Kieran
Hey guys, I'm building a new mill, and would like to run on ethercat servos. I'm wondering if there's any issue running a 5I25 or similar as an input for MPG/buttons/switches and other basic IO things, while using ethercat for the motors.
I'm new to ethercat, but did build a linuxcnc+5i25+steppers mill and lathe about 10y ago. They are still going strong. I'm currently going through trying to relearn all the linuxcnc stuff.
- Hakan
- Thank you received: 463
25 Mar 2025 21:54 #324925
by Hakan
Replied by Hakan on topic I want to run ethercat and a mesa
Don't know about this specific combo, but I have run 7i96 and ethercat on two separate network interfaces without issues.
My guess is it will work just fine.
The following user(s) said Thank You: Kieran
- Kieran
26 Mar 2025 15:14 #324970
by Kieran
Replied by Kieran on topic I want to run ethercat and a mesa
Cool. Thinking about it more, I'm wondering if I should just get a basic generic parallel port card, since I probably don't need fancy FPGA stuff for an MPG and some override switches. I guess I'm just remembering how much better my little cnc conversion runs on the mesa vs the parport. It seems with ethercat, most of that becomes irrelevant.
- Hakan
27 Mar 2025 05:41 - 27 Mar 2025 08:18 #325031
by Hakan
It happens that ethercat drives have inputs and outputs one can use for general purposes.
At least my Ect60s have a few. Meant for internal homing I think, but can be used for anything.
Check the drive specs.
Last edit: 27 Mar 2025 08:18 by Hakan.
Time to create page: 0.066 seconds
