Mode and Scaling
07 May 2025 19:41 #327954 by kubes
Mode and Scaling was created by kubes
I have a new basic setup and I have motion working, and am expanding and fine-tuning from there.
I have a few questions
1. What is the best mode to use? csp? `setp cia402.0.csp-mode 1`
2. Where is the best place to do 'scaling'?  In Linux-CNC (hal & cia402) or in the EtherCAT driver/controller?
3. Where can I fiind documention for `ethercat-conf.xml`, I am using one based on github.com/dbraun1981/hal-cia402/blob/ma...le/ethercat-conf.xml, and want to understand the option and what else should be in there?  I want do add SDOs.
Thanks!!!!
07 May 2025 20:05 #327958 by tommylight
Replied by tommylight on topic Mode and Scaling
Moved to "EtherCAT" section.
08 May 2025 06:05 #327979 by Hakan
Replied by Hakan on topic Mode and Scaling
1. Normally csp I would say. For a spindle motor csv.
2. I prefer to send position in machine units to cia402 and do the scaling closer to the drive. But that's just me.
3. lcec comes from here github.com/linuxcnc-ethercat/linuxcnc-ethercat and there is a link in there to a reference guide. Unfortunately it doesn't cover sdo uploads. But it's done like this. Example comes from one of my ect60 stepper motor drivers.
<slave idx="0" name="X" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Max motor current (3.0A=b80b 4.0=a00f 5.0=8813) Rated=4.0A -->
      <sdoConfig idx="2003" subIdx="0"><sdoDataRaw data ="64 00"/></sdoConfig>  <!-- Standby current percentage (100%) -->
      <sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig>  <!-- Closed loop -->
      <sdoConfig idx="2023" subIdx="1"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Kp=4000 (def=2000) -->
      <syncManager idx="2" dir="out">
The sdoDataRaw has some quirks. First you must enter 4 bytes for a 32-bit variable, 2 bytes for 16 bit and 1 for 8 bit.
Note the byte order, 4000 which is hex 0x0fa0 is entered as "a0 0f". 100 (hex 0x64) is entered as "64 00",
Time to create page: 0.248 seconds
