help with ethercat and omron drives
1 year 5 months ago #329064 by ihavenofish
Sooo, back at my ethercat fun and I think I've made progress, but I'm stuck.
I've gone right to the basics and am just using halshow to poke the drives.
I made a super basic xml file following some other examples on here.
So, following this:
EtherCAT: How to use the dedicated OmrG5 lcec driver? - LinuxCNC $ ethercat slaves shows me my 3 drives just fine
$ ethercat upload -p 0 -t int32 0x6064 0x0 shows me position just fine
$ ethercat safeop doesn't work and returns error 90 because the default sync0Cycle is wrong. This seems expected.
My xml is:
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="generic" vid="#00000083" pid="#00000006">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<watchdog divider="2498" intervals="1000"/>
</slave>
</master>
</masters>(using the generic driver here cause the omron one was saying no drive found)
then we do this in halshow:
loadrt threads name1=master period1=1000000
loadusr -W lcec_conf linuxcnc/configs/ecat-test.xml
loadrt lcec
addf lcec.read-all master
addf lcec.write-all master
start
All works, except after we get to start, the drives show error 83, and if you look at the pins, its actually cycling through preop, safeop, inti, op, error every so many ms.
So what have I done wrong here, or what do I need to add? The are many gaps in the information and steps people provide so I expect there's just something missing I don't know about.
Thanks!
1 year 5 months ago #329066 by Hakan
From that Omron thread, it looks like Arvidb got it working, so can you try with the ecat-conf.xml?
<masters> <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1"> <slave idx="0" type="R88D-KN02H-ECT"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/> <watchdog divider="2498" intervals="1000"/> </slave> </master> </masters>
It's the same xml that Arvidb used, but I have changed to what I think it the right model, based on the product code 6 you use.
1 year 5 months ago #329068 by ihavenofish
Yeah that didn't work. I found a different xml with more "stuff" (pdo, etc) and it has put me in OP mode. even though I don't see any actual difference.
But its progress!
1 year 5 months ago #329069 by ihavenofish
well now all 3 drives are in op mode with no errors showing.
... now what do i do? haha
1 year 5 months ago #329096 by Hakan
Use it?
Use the hal file from here as starting point to get the servos going.
github.com/dbraun1981/hal-cia402/tree/main/example
1 year 5 months ago #329103 by ihavenofish
Hehe that was a joke. Although right now the machine is stuck on estop and I'm not sure why. I'm sure it will be something dumb. :)
Time to create page: 0.228 seconds
