- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Help! Regarding the data reading offset issue of the ether cat IO module
- endian
- Thank you received: 62
28 May 2025 09:30 #329304
by endian
but defenetely you can not let 32bit lenght for halType="bit" I think ...
Replied by endian on topic Help! Regarding the data reading offset issue of the ether cat IO module
Can you share whole config to better understanding please? I am interested in the two masters from your configuration ... how and if it is working? thank youWhen I was testing this signal input, I found that when I turned on LED0, the corresponding IO PIN was lit up at pin number 16. Similarly, the output position was also the same. In summary, the data I currently receive has been shifted by 16 bits. Additionally, I have attached my XML and the test results from Beckhoff (they are all OK). Could someone kind-hearted please tell me why?
Check actual config over, then you will can read active configuration from online slaves... then just copy paste<pdoEntry idx="6000" subIdx="01" bitLen="32" halPin="bit-in" halType="bit"/>
ethercat pdos -v
- Soccer Kid
- Thank you received: 4
29 May 2025 09:27 #329357
by Soccer Kid
Replied by Soccer Kid on topic Help! Regarding the data reading offset issue of the ether cat IO module
Currently, my configuration is rather messy. I will choose to upload it after I have some time to tidy it up later. The current problem has been largely identified. By analyzing the PDO data from different platforms, I identified some subtle differences. I then reported the bugs to the manufacturer and waited for them to provide a new firmware. Once the new firmware is ready, I will post the detailed differences here.
- EtherCAT
Time to create page: 0.061 seconds
