Modbus via Ethercat (Beckhoff)
28 May 2025 15:08 #329318 by SwitchWitch
Replied by SwitchWitch on topic Modbus via Ethercat (Beckhoff)
Thank you so much for your hints and ideas!
Yes the optidrive should stay in my setup - at least for the next months. The switch to ethercat, the new servos aso was hard enough to afford. As you mentioned before usb to rs485 is an option, I will go that way until I will be able to spend the next bucks for an ethercat VFD.
28 May 2025 15:09 #329319 by SwitchWitch
I would really like to, but I have to wait a little bit with the next invest in my hobby.
29 May 2025 01:39 #329337 by rodw
Replied by rodw on topic Modbus via Ethercat (Beckhoff)
I think once you get that going, you will find it works so well, you will never go to an ethercat VFD.
Does Optidrive have a separate ethercat interface module for your VFD? A number of manufacturers do.
The following user(s) said Thank You: SwitchWitch
29 May 2025 10:25 #329359 by SwitchWitch
Thx for your help! I hope that the usb-rs485 solution will work as well as ethercat would do.
I had a closer look on the manual of the Optidrive and unfortunately they don`t offer an ethercat interface for the E3 Series. It has multiple protocols on board but not ethercat. Can open is available and Beckhoff offers a Can open module - but as an absolute newbie it will be impossible to implement it I guess.
31 May 2025 09:43 #329437 by endian
Replied by endian on topic Modbus via Ethercat (Beckhoff)
Hello,
let check this topic  ... It will be in the general 99% same as for CanOpen setup.. but datas config should be little bit different...
regards E..
Time to create page: 0.189 seconds
