Modbus via Ethercat (Beckhoff)
1 year 5 months ago - 1 year 5 months ago #329206 by Hakan
No the EL6021, modbus is usually RS-485 signalling. Not so different from RS-232 but differential signals.
Edit. The USB to RS-485 is a much better option in this case to avoid the vertical learning curve.
Last edit: 1 year 5 months ago by Hakan.
The following user(s) said Thank You: SwitchWitch
1 year 5 months ago #329240 by Soccer Kid
There is not much difference between E6021 and 6001. I usually use these modules on the codesys platform. If I have more time later, I will try to test linuxcnc, but this means it will take a long time. I will test and release a demo as much as possible.
1 year 5 months ago #329285 by rodw
Replied by rodw on topic Modbus via Ethercat (Beckhoff)
Why not use an Ethercat VFD like the Omron MX2 which is supported in the hal driver. I believe internally its a cia402 device since it's essentially a speed control for a motor just like a servo!
1 year 5 months ago #329293 by Hakan
It was mentioned an existing vfd, but to go pure ethercat an ethercat vfd is the way.
It got me to check the manual and yes it is RS-485 Modbus RTU.
1 year 5 months ago #329318 by SwitchWitch
Thank you so much for your hints and ideas!
Yes the optidrive should stay in my setup - at least for the next months. The switch to ethercat, the new servos aso was hard enough to afford. As you mentioned before usb to rs485 is an option, I will go that way until I will be able to spend the next bucks for an ethercat VFD.
1 year 5 months ago #329319 by SwitchWitch
I would really like to, but I have to wait a little bit with the next invest in my hobby.
Time to create page: 0.063 seconds
