SANGE elec IO
  • deltafox24
  • Topic Author
  • New Member
  • New Member
1 year 4 months ago #330013 by deltafox24
SANGE elec IO was created by deltafox24
Hi everyone,
I bought this device: SG-ELC-ADIO-DI16-DO16-PNP.
I wrote a custom XML file for it, but for some reason, after I load it, there's a 90% chance that EtherCAT crashes with an error.
I suspect that it might be slowing down the entire system, or maybe I wrote the XML incorrectly.Here’s what I wrote:
 <slave idx="4" type="generic" vid="EE000002" pid="00010205" configPdos="true" >
            <dcConf assignActivate="0000" sync0Cycle="0" sync0Shift="0"/>
            <syncManager idx="0" dir="out">
                <pdo idx="1a00">
                    <pdoEntry idx="3101" subIdx="1" bitLen="8" halType="complex">
                        <complexEntry bitLen="1" halPin="out-00" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-01" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-02" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-03" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-04" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-05" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-06" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-07" halType="bit"/>
                    </pdoEntry>
                </pdo>
                <pdo idx="1a01">
                    <pdoEntry idx="3101" subIdx="2" bitLen="8" halType="complex">
                        <complexEntry bitLen="1" halPin="out-08" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-09" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-10" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-11" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-12" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-13" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-14" halType="bit"/>
                        <complexEntry bitLen="1" halPin="out-15" halType="bit"/>
                    </pdoEntry>
                </pdo>
            </syncManager>
            <syncManager idx="2" dir="in">
                <pdo idx="1600">
                    <pdoEntry idx="3001" subIdx="1" bitLen="8" halType="complex">
                        <complexEntry bitLen="1" halPin="in-00" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-01" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-02" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-03" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-04" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-05" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-06" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-07" halType="bit"/>
                    </pdoEntry>
                </pdo>
                <pdo idx="1601">
                    <pdoEntry idx="3001" subIdx="2" bitLen="8" halType="complex">
                        <complexEntry bitLen="1" halPin="in-08" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-09" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-10" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-11" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-12" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-13" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-14" halType="bit"/>
                        <complexEntry bitLen="1" halPin="in-15" halType="bit"/>
                    </pdoEntry>
                </pdo>
            </syncManager>
        </slave>
And I’m also attaching the original XML file.
1 year 4 months ago - 1 year 4 months ago #330055 by Hakan
Replied by Hakan on topic SANGE elec IO
Run the "lcec_configgen" command and compare.
Also check for relevant error messages from the command "sudo dmesg"
Edit, and according to the xml you attached, output 8 to 15 is in syncmanager 1, but you'll see that.
Last edit: 1 year 4 months ago by Hakan.
  • deltafox24
  • Topic Author
  • New Member
  • New Member
1 year 4 months ago #330101 by deltafox24
Replied by deltafox24 on topic SANGE elec IO
thanks for the tip, i got the lcec_configgen file
   <slave idx="4" type="generic" vid="0xee000002" pid="0x00010205" name="D5">       <!--SG-ELC-ADIO-DI16-DO16-PNP(Digital 16-Input/16-Output)-->       <syncManager idx="0" dir="out">         <pdo idx="1a00">           <!--Output Group 0-->           <pdoEntry idx="3101" subIdx="01" bitLen="8" halPin="output-00-07-" halType="BLANK"/>         </pdo>       </syncManager>       <syncManager idx="1" dir="out">         <pdo idx="1a01">           <!--Output Group 1-->           <pdoEntry idx="3101" subIdx="02" bitLen="8" halPin="output-08-15-" halType="BLANK"/>         </pdo>       </syncManager>       <syncManager idx="2" dir="in">         <pdo idx="1600">           <!--Input Group 0-->           <pdoEntry idx="3001" subIdx="01" bitLen="8" halPin="input-00-07-" halType="BLANK"/>         </pdo>         <pdo idx="1601">           <!--Input Group 1-->           <pdoEntry idx="3001" subIdx="02" bitLen="8" halPin="input-08-15-" halType="BLANK"/>         </pdo>       </syncManager>     </slave>
Based on it, I modified my XML file in this way
  <!-- IO --> <slave idx="4" type="generic" vid="EE000002" pid="00010205" configPdos="true">   <dcConf assignActivate="0000" sync0Cycle="0" sync0Shift="0"/>     <syncManager idx="0" dir="out">     <pdo idx="1a00">       <pdoEntry idx="3101" subIdx="1" bitLen="8" halType="complex">         <complexEntry bitLen="1" halPin="out-00" halType="bit"/>         <complexEntry bitLen="1" halPin="out-01" halType="bit"/>         <complexEntry bitLen="1" halPin="out-02" halType="bit"/>         <complexEntry bitLen="1" halPin="out-03" halType="bit"/>         <complexEntry bitLen="1" halPin="out-04" halType="bit"/>         <complexEntry bitLen="1" halPin="out-05" halType="bit"/>         <complexEntry bitLen="1" halPin="out-06" halType="bit"/>         <complexEntry bitLen="1" halPin="out-07" halType="bit"/>       </pdoEntry>     </pdo>   </syncManager>     <syncManager idx="1" dir="out">     <pdo idx="1a01">       <pdoEntry idx="3101" subIdx="2" bitLen="8" halType="complex">         <complexEntry bitLen="1" halPin="out-08" halType="bit"/>         <complexEntry bitLen="1" halPin="out-09" halType="bit"/>         <complexEntry bitLen="1" halPin="out-10" halType="bit"/>         <complexEntry bitLen="1" halPin="out-11" halType="bit"/>         <complexEntry bitLen="1" halPin="out-12" halType="bit"/>         <complexEntry bitLen="1" halPin="out-13" halType="bit"/>         <complexEntry bitLen="1" halPin="out-14" halType="bit"/>         <complexEntry bitLen="1" halPin="out-15" halType="bit"/>       </pdoEntry>     </pdo>   </syncManager>     <syncManager idx="2" dir="in">     <pdo idx="1600">       <pdoEntry idx="3001" subIdx="1" bitLen="8" halType="complex">         <complexEntry bitLen="1" halPin="in-00" halType="bit"/>         <complexEntry bitLen="1" halPin="in-01" halType="bit"/>         <complexEntry bitLen="1" halPin="in-02" halType="bit"/>         <complexEntry bitLen="1" halPin="in-03" halType="bit"/>         <complexEntry bitLen="1" halPin="in-04" halType="bit"/>         <complexEntry bitLen="1" halPin="in-05" halType="bit"/>         <complexEntry bitLen="1" halPin="in-06" halType="bit"/>         <complexEntry bitLen="1" halPin="in-07" halType="bit"/>       </pdoEntry>     </pdo>     <pdo idx="1601">       <pdoEntry idx="3001" subIdx="2" bitLen="8" halType="complex">         <complexEntry bitLen="1" halPin="in-08" halType="bit"/>         <complexEntry bitLen="1" halPin="in-09" halType="bit"/>         <complexEntry bitLen="1" halPin="in-10" halType="bit"/>         <complexEntry bitLen="1" halPin="in-11" halType="bit"/>         <complexEntry bitLen="1" halPin="in-12" halType="bit"/>         <complexEntry bitLen="1" halPin="in-13" halType="bit"/>         <complexEntry bitLen="1" halPin="in-14" halType="bit"/>         <complexEntry bitLen="1" halPin="in-15" halType="bit"/>       </pdoEntry>     </pdo>   </syncManager> </slave>
but still after using the IO module, I get an error when lifting the zed axis.
1 year 4 months ago #330125 by Hakan
Doesn't immediately sound related. Would expect a digital IO from the unit to be involved
and not only movement of an axis.
There are some ways to troubleshoot
- any error or info message, if any, in a popup window from the hmi
- any error or info output from linuxcnc in the terminal window where it is started
- the last say 20 line from the command "sudo dmesg" especially when ethercat related
and one then need to match that with the configuration
- hal file
- ini file
- ethercat-conf.xml
Sometimes the error is obvious, more often the info doesn't directly identify the problem.
You can have a go and look at the info and see if you can spot where it goes wrong, and why.
I can have a look too but then I need all listed info.
  • deltafox24
  • Topic Author
  • New Member
  • New Member
11 months 4 weeks ago #337890 by deltafox24
The SANGE I/O module has an unreliable EtherCAT implementation — it often loses connection and is not detected reliably in the network. The ESI file is either missing or contains errors, which requires manual editing.The polling cycle is no better than 10 ms, which is too slow for real-time control.Hardware quality is poor: weak isolation and possible false input triggers.There is practically no support from the manufacturer.
Overall, not worth buying.
11 months 4 weeks ago #337898 by Hakan
Not so good news, but good with feedback. Will help the next guy to make a decision.
I guess the I/O module isn't EtherCAT certified if it performs so poorly?
  • deltafox24
  • Topic Author
  • New Member
  • New Member
11 months 3 weeks ago - 11 months 3 weeks ago #337940 by deltafox24
I don't know about certification. But I do know that the system crashed in 80% of cases when I used this module. I installed CATIO-A and the system started working stably.
Last edit: 11 months 3 weeks ago by deltafox24.
11 months 3 weeks ago #337947 by Hakan
What I noticed right away was that they use SyncManager 0 for process data. This is not normal.
SyncManagers 2 and above are for process data, SM 0 and 1 are for mailboxes and handles SDO upload/download especially during the early phases like INIT.
I don't think you can change the syncmanagers, the device has what it has, but a wild experiment could be to change the SyncManager idx="0" to idx="3". If you haven't thrown the device in the bin already :)
Time to create page: 0.071 seconds
