cia402_homecomp , Are there any config sample?  (Lichuan LC10E + Simple XYZ)
12 Jun 2025 11:14 #330202 by tar_san
Hi, everyone.
I have a trouble getting LinuxCNC work about homing  with Lichuan LC10E Servo drive.
My LinuxCNC System can move XYZ GCode with CSP Mode.
But I could not use homeing function.
I believe I should use cia402_homecomp.
I tried configurate my ini, hal, xml to use cia402_homecomp manually, using LC10E-driver's homing function,  but I failed to work it so far.
I hope, I can find any configuration about this library as a example.
Are there any LinuxCNC configuration files about it ?
Thanks.
12 Jun 2025 23:55 - 13 Jun 2025 00:05 #330238 by COFHAL
Last edit: 13 Jun 2025 00:05 by COFHAL.
14 Jun 2025 07:32 #330270 by tar_san
Thank you ,but I could not find out any useful information in that whole thread.
I'd like to know how to do homeing with Lichuan LC10E Servo drive.
I'm using cia402_homecomp with fixing of cia402.comp line 240.
Are some of successful forum discussions out of date ?
Time to create page: 0.076 seconds
