Getting Ebay 2.6kw ethercat kit going.
19 Jun 2025 04:58 - 19 Jun 2025 05:05 #330488 by Kieran
Im trying to get my 2.6kw spindle servo going. its got a P200SE drive. the instructions are written in Chinese. I used google translate and it worked pretty good. Right now im running it as a Z axis just to see if i can get it working. I got my XML setup enough that Linuxcnc reads the encoder no problem. the servo powers up and holds position along with my stepperonline X and y servos. my current roadblock is that its not listening to commands and doesnt move and it gets a following error shortly after. if i power off and turn the motor the DRO moves the distance expected so that's a good sign. the servo load meter on the PYvcp is workign for this servo too, when i "fight" the servo. i must just be missing something simple in my XML?
lcec_configgen gives me this
Warning: Spoiler!
my xml so far
Warning: Spoiler!
Last edit: 19 Jun 2025 05:05 by Kieran.
20 Jun 2025 03:58 - 20 Jun 2025 04:02 #330546 by Kieran
Replied by Kieran on topic Getting Ebay 2.6kw ethercat kit going.
well I reRan lcec_configgen and got a different reading on slave IDX 2 not sure why. I was able to fart around with the XML and get the servo going. it about jumped off my bench. she's a ripper.
working XML snippet for the Ebay servo/ DVS P200SE drive.
Warning: Spoiler!
Last edit: 20 Jun 2025 04:02 by Kieran.
Time to create page: 0.181 seconds
