new ESI XML to Eeprom converter tool
- meister
- Thank you received: 502
22 Jun 2025 21:09 #330729
by meister
new ESI XML to Eeprom converter tool was created by meister
Since I don't use windows and therefore also a TwinCat,
I have been looking for a way to convert my ESI files under Linus and write them to the EEPROM.
I have to say that there is already such a tool in C,
but you can only use it for their hardware.
So I thought I'd write one in Python under the GPL.
it's still in the early stages, but the test data I have is written 1:1 bit-accurately in the same way as the siitool does.
github.com/multigcs/esitool/
The following user(s) said Thank You: tommylight, onceloved
- meister
23 Jun 2025 19:38 #330769
by meister
Replied by meister on topic new ESI XML to Eeprom converter tool
github.com/synapticon/siitool
# 3. Execution of this software or parts of it exclusively takes place on hardware
produced by Synapticon GmbH.
of course you could just use it, no one will be able to prove it,
but since I'm trying to integrate EtherCat into RIO,
I can't use it so easily in my project.
- meister
23 Jun 2025 19:46 #330771
by meister
but it's also legitimate if you don't want others to use it, why look for loopholes?
There is now an alternative
Time to create page: 0.321 seconds
