How to use Fixed PDO mapping on Lichuan LC Servo
16 Jul 2025 00:38 #331875 by tar_san
I have a question. How to use Fixed PDO mapping on Lichuan LC Servo?
I used 10 entries in PDO 1600h ( Variable PDO ) in ethercat-conf.xml ( 10 entries are maximum )
So I just moved some <pdoEntry>  to FixedPDO (1704h )
But it didn't work.
Do I have to do something to use FixedPDO ?
Are there any good example for it ?
16 Jul 2025 07:29 #331885 by Hakan
My understanding is that you can't change the pdoentries in a fixed PDO, they are hmm fixed.
The variable PDOs can be populated with pdoentries according to your need.
The following user(s) said Thank You: tar_san
17 Jul 2025 18:08 #331947 by Kieran
I played with 1704 on my servos and you have to have every single fixed pdo matching in your xml. if you accidentally have an extra one, or one less, or a wrong one that's not in the fixed pdo, it wont work.
22 Jul 2025 10:45 #332170 by tar_san
Thank you. I will try to define the same address exactly later.
Time to create page: 0.340 seconds
