modprobe: ERROR: could not insert 'ec_master': Key was rejected by service
  • GDTH
  • GDTH's Avatar Topic Author
  • Senior Member
  • Senior Member
02 Aug 2025 16:23 #332681 by GDTH
Hello
i am trying to setup ethercat on linuxcnc 2.9.4.
I use these instructions
when i want to start the service it gives an error:
these are the conf params i set:
MASTER0_DEVICE="dc:4a:3e:52:df:de"
DEVICE_MODULES="generic"
i based it on this:
 ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 xdpgeneric/id:15 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether dc:4a:3e:52:df:de brd ff:ff:ff:ff:ff:ff
    inet 192.168.8.103/24 brd 192.168.8.255 scope global dynamic noprefixroute enp1s0
       valid_lft 42941sec preferred_lft 42941sec
    inet6 fe80::5746:54a6:d185:a5cd/64 scope link noprefixroute
3: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 88:c9:b3:bb:01:3c brd ff:ff:ff:ff:ff:ff
4: wt0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1280 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 100.113.80.7/16 brd 100.113.255.255 scope global wt0
Does anyone know where i went wrong?
I did first install it and find out that i was on a sercure boot, so i disabled it in the bios.
Kind regards,
Andries
  • Moderator
  • Moderator
08 Aug 2025 23:33 #333081 by tommylight
Please post output of ip a
He did, so why ask again?
On topic, that seems an issue with the EtherCAT key, it has nothing to do with networking, also supported by "modprobe" in the error as the module could not be loaded/inserted.
09 Aug 2025 08:25 #333097 by Hakan
Certainly an issue with secure boot and unsigned kernel modules, so the author is on the right track.
Twenty lines down there is a hidden spoiler section with more instructions, in case they were not seen.
The ec_master and ec_generic modules are built during ethercat package installation to fit the current kernel.
The modules do not get signed properly as required by secure boot. There was a case some months back
despite switching off secure boot in bios the kernel refused to load the modules.
By googling around it seems possible the modules can be signed but it is not so easy, but you can always try.
Switching off secure boot should work but doesn't always it seems.
09 Aug 2025 11:55 #333115 by rodw
Its quite possible to get linuxcnc and Ethercat working with secure boot. The instructions you followed have a spoiler to open  explaining how to do it. The method came from the ethercat guys and I have tested it as working.
The following user(s) said Thank You:
Time to create page: 0.184 seconds
