AMSAMOTION IO module
- Kuzma30
02 Sep 2025 06:22 #334259
by Kuzma30
AMSAMOTION IO module was created by Kuzma30
I have EC3A-IO1632 module and trying connect it with linuxcnc.
I am following instruction from here forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step and stop at ethercat slaves step.
When trying list slaves with ethercat slaves command I get empty output.Output for ethercat masterI trying different Ethernet cable with same results
ethercat master
Master0
Phase: Waiting for device(s)...
Active: no
Slaves: 0
Ethernet devices:
Main: 78:45:c4:23:9f:86 (waiting...)
Link: DOWN
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 0 0 0
Tx rate [KByte/s]: 0.0 0.0 0.0
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000Please Log in or Create an account to join the conversation.
- Hakan
- Thank you received: 497
03 Sep 2025 02:42 #334318
by Hakan
Replied by Hakan on topic AMSAMOTION IO module
The Ethercat server appears to be working but cannot connect to the network interface.
You should see something like thisLook out for "(attached)" and "Link: UP"
There are several possible reason
- wrong module name or mac address in /etc/ethercat.conf
- network interface is not "up"
- your system uses secure boot, UEFI, ethercat kernel modules can not be loaded. Check some 15 lines down in "sticky", the spoiler section.
debian@plasma:~$ ethercat master
Master0
Phase: Idle
Active: no
Slaves: 4
Ethernet devices:
Main: c4:62:37:06:66:54 (attached)
Link: UPThere are several possible reason
- Kuzma30
03 Sep 2025 02:57 #334320
by Kuzma30
Replied by Kuzma30 on topic AMSAMOTION IO module
cnc@cnc:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 78:45:c4:23:9f:86 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.100/24 brd 192.168.0.255 scope global noprefixroute enp2s0
inet6 fe80::7a45:c4ff:fe23:9f86/64 scope link
cnc@cnc:~$ lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation H61 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
cnc@cnc:~$ cat /etc/ethercat.conf
# EtherCAT master configuration file for use with ethercatctl.
# vim: spelllang=en spell tw=78
# Main Ethernet devices.
# The MASTER<X>_DEVICE variable specifies the Ethernet device for a master
# with index 'X'.
# Specify the MAC address (hexadecimal with colons) of the Ethernet device to
# use. Example: "00:00:08:44:ab:66"
# Alternatively, a network interface name can be specified. The interface
# name will be resolved to a MAC address using the 'ip' command.
# Example: "eth0"
# The broadcast address "ff:ff:ff:ff:ff:ff" has a special meaning: It tells
# the master to accept the first device offered by any Ethernet driver.
# The MASTER<X>_DEVICE variables also determine, how many masters will be
# created: A non-empty variable MASTER0_DEVICE will create one master, adding a
# non-empty variable MASTER1_DEVICE will create a second master, and so on.
# Examples:
# MASTER0_DEVICE="00:00:08:44:ab:66"
# MASTER0_DEVICE="eth0"
MASTER0_DEVICE="enp2s0"
#DEVICE_MODULES="generic"
#MASTER1_DEVICE=""
# Backup Ethernet devices
# The MASTER<X>_BACKUP variables specify the devices used for redundancy. They
# behaves nearly the same as the MASTER<X>_DEVICE variable, except that it
# does not interpret the ff:ff:ff:ff:ff:ff address.
#MASTER0_BACKUP=""
# Ethernet driver modules to use for EtherCAT operation.
# Specify a non-empty list of Ethernet drivers, that shall be used for
# EtherCAT operation.
# Except for the generic Ethernet driver module, the init script will try to
# unload the usual Ethernet driver modules in the list and replace them with
# the EtherCAT-capable ones. If a certain (EtherCAT-capable) driver is not
# found, a warning will appear.
# Possible values: 8139too, e100, e1000, e1000e, r8169, generic, ccat, igb, igc, genet, dwmac-intel, stmmac-pci.
# Separate multiple drivers with spaces.
# A list of all matching kernel versions can be found here:
# https://docs.etherlab.org/ethercat/1.6/doxygen/devicedrivers.html
# Note: The e100, e1000, e1000e, r8169, ccat, igb and igc drivers are not built by
# default. Enable them with the --enable-<driver> configure switches.
DEVICE_MODULES=""
# If you have any issues about network interfaces not being configured
# properly, systemd may need some additional infos about your setup.
# Have a look at the service file, you'll find some details there.
# List of interfaces to bring up and down automatically.
# Specify a space-separated list of interface names (such as eth0 or
# enp0s1) that shall be brought up on `ethercatctl start` and down on
# `ethercatctl stop`.
# When using the generic driver, the corresponding Ethernet device has to be
# activated before the master is started, otherwise all frames will time out.
# This the perfect use-case for `UPDOWN_INTERFACES`.
UPDOWN_INTERFACES=""
# Flags for loading kernel modules.
# This can usually be left empty. Adjust this variable, if you have problems
# with module loading.
#MODPROBE_FLAGS="-b"
- Kuzma30
03 Sep 2025 03:01 #334321
by Kuzma30
I have not UEFI and enp2s0 is UP
cnc@cnc:~$ sudo mokutil --sb-state
EFI variables are not supported on this system
cnc@cnc:~$ ip a
valid_lft forever preferred_lft foreverPlease Log in or Create an account to join the conversation.
- Hakan
03 Sep 2025 03:09 - 03 Sep 2025 03:14 #334323
by Hakan
Check the output of "sudo dmesg" after you do "sudo systemctl restart ethercat" for clues.
Last edit: 03 Sep 2025 03:14 by Hakan. Reason: restart command
- Kuzma30
03 Sep 2025 04:12 #334327
by Kuzma30
[ 7042.964030] EtherCAT: Master module cleaned up.
[ 7044.047160] EtherCAT: Master driver 1.6.7 1.6.7.gc1e6b50-1+26.2
[ 7044.047314] EtherCAT: 1 master waiting for devices.Please Log in or Create an account to join the conversation.
- Hakan
03 Sep 2025 05:09 #334331
by Hakan
Settings in /etc/ethercat.conf ok? Should readAre both kernel modules loaded? I guess not.
MASTER0_DEVICE="78:45:c4:23:9f:86"
...$ lsmod | grep ^ec_
ec_generic 12288 0
ec_master 479232 1 ec_generic
The following user(s) said Thank You: Kuzma30
- Kuzma30
04 Sep 2025 02:41 #334391
by Kuzma30
ec_generic was not loaded.
After modprobe it I can see slaves
How to autoload it?
ethercat slaves
0 0:0 PREOP + EC3A-IO1632How to autoload it?
- Hakan
04 Sep 2025 05:14 - 04 Sep 2025 05:27 #334396
by Hakan
ec_generic should autoload when ethercat master service is started and "generic" is mentioned in /etc/ethercat.conf
There was an issue where it didn't and the user had to modprobe it manually after start of linux.
Suspected Secure boot but it was off like in your case. Never understood why it didn't load.
I guess you have to experiment to see if you can get it to autoload.
/usr/sbin/ethercatctl is the file that loads the modules when the service is started, it's a bash script.
Last edit: 04 Sep 2025 05:27 by Hakan. Reason: ethercatctl
The following user(s) said Thank You: ts
- Kuzma30
05 Sep 2025 06:27 #334484
by Kuzma30
I have such info for my module.
How to make xml config file for it?
ethercat xml
<?xml version="1.0" ?>
<EtherCATInfo>
<!-- Slave 0 -->
<Vendor>
<Id>2965</Id>
</Vendor>
<Descriptions>
<Devices>
<Device>
<Type ProductCode="#x00001101" RevisionNo="#x01020109">EC3A-IO1632</Type>
<Name><![CDATA[EC3A-IO1632]]></Name>
<Sm Enable="1" StartAddress="#x1000" ControlByte="#x26" DefaultSize="128" />
<Sm Enable="1" StartAddress="#x1080" ControlByte="#x22" DefaultSize="128" />
<Sm Enable="1" StartAddress="#x1100" ControlByte="#x64" DefaultSize="2" />
<Sm Enable="1" StartAddress="#x1400" ControlByte="#x20" DefaultSize="2" />
<RxPdo Sm="2" Fixed="1" Mandatory="1">
<Index>#x1600</Index>
<Name>DOOutputs process data mapping</Name>
<Entry>
<Index>#x7000</Index>
<SubIndex>1</SubIndex>
<BitLen>16</BitLen>
<Name>OUT_GEN_DO</Name>
<DataType>UINT16</DataType>
</Entry>
</RxPdo>
<TxPdo Sm="3" Fixed="1" Mandatory="1">
<Index>#x1a00</Index>
<Name>DIInputs process data mapping</Name>
<Entry>
<Index>#x6000</Index>
<BitLen>16</BitLen>
<Name>IN_GEN_DI</Name>
</Entry>
</TxPdo>
</Device>
</Devices>
</Descriptions>
</EtherCATInfo>
cnc@cnc:~$ ethercat pdos
SM0: PhysAddr 0x1000, DefaultSize 128, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1080, DefaultSize 128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1100, DefaultSize 2, ControlRegister 0x64, Enable 1
RxPDO 0x1600 "DOOutputs process data mapping"
PDO entry 0x7000:01, 16 bit, "OUT_GEN_DO"
SM3: PhysAddr 0x1400, DefaultSize 2, ControlRegister 0x20, Enable 1
TxPDO 0x1a00 "DIInputs process data mapping"
PDO entry 0x6000:01, 16 bit, "IN_GEN_DI"How to make xml config file for it?
Time to create page: 0.103 seconds
