Ethercat drives not responding, mesa error finishing read
1 year 3 weeks ago #336043 by nanowhat
sudo ./pinirq_2025-10-07.sh enp5s0
returns
"Cores: 8
Old CPU Mask: ff
./pinirq_2025-10-07.sh: line 18: echo: write error: Value too large for defined data type
Set device enp5s0 IRQ 30 CPU mask to ff"
1 year 3 weeks ago #336047 by PCW
That's an odd error since the new mask should be 128=080H
and the existing mask is 255=0FFH
1 year 3 weeks ago #336066 by nanowhat
I've installed Debian 13 (kernel is 6.12.48) on a different computer, and attempted to build linuxcnc and ethercat from source as described at  forum.linuxcnc.org/ethercat/54712-etherc...ons-updated-for-2024 and the results are the same:
ethercat -p0 upload -t int32 0x6064 0
returned Failed to upload SDO: Input/output error 7 out of 12 tries.
Now I wonder if there is actually a problem with LinuxCNC and ethercat, or if the drives are doing something strange.
1 year 3 weeks ago - 1 year 3 weeks ago #336184 by Hakan
Try this small example config. That should make one axis work.
If it doesn't it is much easier to troubleshoot.
github.com/dbraun1981/hal-cia402/tree/main/example
Last edit: 1 year 3 weeks ago by Hakan. Reason: one axis
1 year 3 weeks ago #336218 by nanowhat
I can try it, but since ethercat at the command line (linuxcnc isn't even running) shows ~50% lost uploads, what's the point?
I don't think this is a linuxcnc problem, but rather some networking or drive problem.
1 year 3 weeks ago #336241 by tommylight
sudo apt install wireshark
monitor the network card to see what is going on, look for retransmissions
Time to create page: 0.055 seconds
