Ethercat drives not responding, mesa error finishing read
1 year 3 weeks ago #336247 by Hakan
So you built ethercat master from source? Rebuild with the option --disable-eoe or something that makes it exclude eoe.
The three lines you showed from the syslog says it want to establish eoe network interfaces. Disable that.
1 year 3 weeks ago - 1 year 3 weeks ago #336266 by Hakan
Since you have problems with the Realtek adapters, here is a tip.
Add an Intel PCIe network adapter. Of course you need a free PCIe slot. With an X4 slot you can use a board with multiple interfaces.
And if you only have an M.2 slot you can use that  forum.linuxcnc.org/18-computer/55782-adding-a-m-2-ethernet-port
Last edit: 1 year 3 weeks ago by Hakan.
1 year 2 weeks ago #336318 by rodw
You mentioned you should have an Intel driver. In which case the R8168-dkms won't be installed or do anything. Start at the beginning
what doeslspci | grep -i ethernet
report?
1 year 2 weeks ago #336408 by shaying526
I have the same situation as you. If I solve it, I will reply below
11 months 6 days ago - 11 months 6 days ago #339271 by nanowhat
Having mostly put the machine together and found ModbusTCP unsuitable, I took another attempt at Ethercat.
  1. I installed LinuxCNC 2.9.4 from the ISO on the nearest available beige box (which has a Realtek ethernet card)
  2. I installed the r8168-dkms driver
  3. I built ethercat from source to exclude EoE as follows:
    1. git clone gitlab.com/etherlab.org/ethercat.git ethercat-master
    2. cd ethercat-master/
    3. git checkout stable-1.6
    4. ./bootstrap (I didn't have autoconf or libtool installed: they are necessary)
    5. ./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --enable-generic --disable-eoe
    6. make all modules
    7. sudo su
    8. make modules_install install
    9. depmod
    10. exit
    11. sudo nano /etc/ethercat.conf
    12. sudo systemctl enable ethercat.service
    13. sudo systemctl start ethercat.service
    14. sudo systemctl status ethercat.service
    15. sudo chmod 666 /dev/EtherCAT0
    16. sudo nano /etc/udev/rules.d/99-ethercat.rules
    17. sudo udevadm control --reload-rules
  4. I installed linuxcnc-ethercat from the repository
  5. I installed the CIA402 module:
    1. git clone github.com/dbraun1981/hal-cia402
    2. sudo halcompile --install cia402.comp
And it works very nicely most of the time. See attached ethercat xml file.
I see some "PLL error" failures sometimes, which can only be "solved" by restarting the control process. I've tried adjusting refClockSyncCycles and sync0Shift in accordance with some other threads, but I don't understand what those do or what they should actually be.
Last edit: 11 months 6 days ago by nanowhat.
11 months 6 days ago #339274 by Hakan
PLL was documented not long ago. Wasn't aware it can stop linuxcnc, that's a bit excessive.
github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
Time to create page: 0.083 seconds
