Festo CMMT-ST
- lorenzing
02 Nov 2025 10:06 #337701
by lorenzing
Replied by lorenzing on topic Festo CMMT-ST
Thank you so much, now looks good.
Can someone help me with "setp cia402.X.pos-scale 3600" value?
I've this type of motor with the same encoder: EMMB-ST-87-M-SM (X), EMMB-ST-87-M-SMB (Z1,Z2,Y1,Y2).
Z1, Z2 5mm/rev; X, Y1, Y2 180mm/rev.
- lorenzing
20 Nov 2025 14:36 #338799
by lorenzing
Many problems have been solved by assigning numbers instead of the axis letter (e.g. X) in the .hal file probably generated errors as there were two motors for one axis.
# --- load components ---
loadrt [KINS]KINEMATICS
# load EtherCAT xml then drivers
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
loadrt cia402 count=5
# --- add functions to servo-thread ---
addf lcec.read-all servo-thread
# read from cia402 drivers (one per joint)
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf cia402.3.read-all servo-thread
addf cia402.4.read-all servo-thread
# motion stack
# writes: cia402 then lcec
addf cia402.0.write-all servo-thread
addf cia402.1.write-all servo-thread
addf cia402.2.write-all servo-thread
addf cia402.3.write-all servo-thread
addf cia402.4.write-all servo-thread
addf lcec.write-all servo-thread
# estop
net estop-out iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in
# JOINT 0 (X) -> cia402.0 -> lcec.0.0
#config
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale -3600
#from servo(ethercat) to cia402
net 0-statusword lcec.0.0.srv-cia-statusword => cia402.0.statusword
net 0-opmode-display lcec.0.0.srv-opmode-display => cia402.0.opmode-display
net 0-drv-act-pos lcec.0.0.srv-actual-position => cia402.0.drv-actual-position
net 0-drv-act-velo lcec.0.0.srv-actual-velocity => cia402.0.drv-actual-velocity
#from cia402 to servo(ethercat)
net 0-controlword cia402.0.controlword => lcec.0.0.srv-cia-controlword
net 0-modes-of-operation cia402.0.opmode => lcec.0.0.srv-opmode
net 0-drv-target-pos cia402.0.drv-target-position => lcec.0.0.srv-target-position
#from motion to cia
net 0-enable <= joint.0.amp-enable-out => cia402.0.enable
net 0-amp-fault => joint.0.amp-fault-in <= cia402.0.drv-fault
net 0-pos-cmd <= joint.0.motor-pos-cmd => cia402.0.pos-cmd
net 0-pos-fb => joint.0.motor-pos-fb <= cia402.0.pos-fb
# JOINT 1 (Y1) -> cia402.1 -> lcec.0.2
#config
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale -3600
net 1-statusword lcec.0.2.srv-cia-statusword => cia402.1.statusword
net 1-opmode-display lcec.0.2.srv-opmode-display => cia402.1.opmode-display
net 1-drv-act-pos lcec.0.2.srv-actual-position => cia402.1.drv-actual-position
net 1-drv-act-velo lcec.0.2.srv-actual-velocity => cia402.1.drv-actual-velocity
net 1-controlword cia402.1.controlword => lcec.0.2.srv-cia-controlword
net 1-modes-of-operation cia402.1.opmode => lcec.0.2.srv-opmode
net 1-drv-target-pos cia402.1.drv-target-position => lcec.0.2.srv-target-position
#from motion to cia
net 1-enable <= joint.1.amp-enable-out => cia402.1.enable
net 1-amp-fault => joint.1.amp-fault-in <= cia402.1.drv-fault
net 1-pos-cmd <= joint.1.motor-pos-cmd => cia402.1.pos-cmd
net 1-pos-fb => joint.1.motor-pos-fb <= cia402.1.pos-fb
# JOINT 2 (Y2) -> cia402.2 -> lcec.0.1
#config
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 3600
net 2-statusword lcec.0.1.srv-cia-statusword => cia402.2.statusword
net 2-opmode-display lcec.0.1.srv-opmode-display => cia402.2.opmode-display
net 2-drv-act-pos lcec.0.1.srv-actual-position => cia402.2.drv-actual-position
net 2-drv-act-velo lcec.0.1.srv-actual-velocity => cia402.2.drv-actual-velocity
net 2-controlword cia402.2.controlword => lcec.0.1.srv-cia-controlword
net 2-modes-of-operation cia402.2.opmode => lcec.0.1.srv-opmode
net 2-drv-target-pos cia402.2.drv-target-position => lcec.0.1.srv-target-position
#from motion to cia
net 2-enable <= joint.2.amp-enable-out => cia402.2.enable
net 2-amp-fault => joint.2.amp-fault-in <= cia402.2.drv-fault
net 2-pos-cmd <= joint.2.motor-pos-cmd => cia402.2.pos-cmd
net 2-pos-fb => joint.2.motor-pos-fb <= cia402.2.pos-fb
# JOINT 3 (Z1) -> cia402.3 -> lcec.0.4
#config
setp cia402.3.csp-mode 1
setp cia402.3.pos-scale 3600
net 3-statusword lcec.0.4.srv-cia-statusword => cia402.3.statusword
net 3-opmode-display lcec.0.4.srv-opmode-display => cia402.3.opmode-display
net 3-drv-act-pos lcec.0.4.srv-actual-position => cia402.3.drv-actual-position
net 3-drv-act-velo lcec.0.4.srv-actual-velocity => cia402.3.drv-actual-velocity
net 3-controlword cia402.3.controlword => lcec.0.4.srv-cia-controlword
net 3-modes-of-operation cia402.3.opmode => lcec.0.4.srv-opmode
net 3-drv-target-pos cia402.3.drv-target-position => lcec.0.4.srv-target-position
#from motion to cia
net 3-enable <= joint.3.amp-enable-out => cia402.3.enable
net 3-amp-fault => joint.3.amp-fault-in <= cia402.3.drv-fault
net 3-pos-cmd <= joint.3.motor-pos-cmd => cia402.3.pos-cmd
net 3-pos-fb => joint.3.motor-pos-fb <= cia402.3.pos-fb
# JOINT 4 (Z2) -> cia402.4 -> lcec.0.3
#config
setp cia402.4.csp-mode 1
setp cia402.4.pos-scale 3600
net 4-statusword lcec.0.3.srv-cia-statusword => cia402.4.statusword
net 4-opmode-display lcec.0.3.srv-opmode-display => cia402.4.opmode-display
net 4-drv-act-pos lcec.0.3.srv-actual-position => cia402.4.drv-actual-position
net 4-drv-act-velo lcec.0.3.srv-actual-velocity => cia402.4.drv-actual-velocity
net 4-controlword cia402.4.controlword => lcec.0.3.srv-cia-controlword
net 4-modes-of-operation cia402.4.opmode => lcec.0.3.srv-opmode
net 4-drv-target-pos cia402.4.drv-target-position => lcec.0.3.srv-target-position
#from motion to cia
net 4-enable <= joint.4.amp-enable-out => cia402.4.enable
net 4-amp-fault => joint.4.amp-fault-in <= cia402.4.drv-fault
net 4-pos-cmd <= joint.4.motor-pos-cmd => cia402.4.pos-cmd
net 4-pos-fb => joint.4.motor-pos-fb <= cia402.4.pos-fb
# End of HALPlease Log in or Create an account to join the conversation.
Time to create page: 0.065 seconds
