Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
1 year 1 week ago #336919 by SPH
Hoping I can get some help getting my new Delta E3 drives up and running.
I've done a fresh install on a mini pc with two realtek 2.5gb nics.
Followed all of the instructions in RodW's very helpful guide and have gotten as far as trying to get my drives setup in the ethercat-conf.xml file, at least that's where I think I'm at.
I ran lcnc for the first time and made a sim gantry setup to get a hal and ini file.
Added the ethercat.hal
added the link to the ethercat-conf.xml and downloaded the xml file from Rod's github.
My drive is powered on and in Ethercat mode.
When I run ethercat slaves from the command line I get the following info
cnc@CNC:~$ ethercat slaves 0  0:0  PREOP  +  0x000001dd:0x10306081 cnc@CNC:~$
Ethercat master returns the following
cnc@CNC:~$ ethercat master Master0   Phase: Idle   Active: no   Slaves: 1   Ethernet devices:     Main: 84:47:09:4b:f6:48 (attached)       Link: UP       Tx frames:   495013       Tx bytes:    29781420       Rx frames:   495012       Rx bytes:    29781360       Tx errors:   0       Tx frame rate [1/s]:    120    122    121       Tx rate [KByte/s]:      7.0    7.1    7.1       Rx frame rate [1/s]:    120    122    121       Rx rate [KByte/s]:      7.0    7.1    7.1     Common:       Tx frames:   675263       Tx bytes:    40660804       Rx frames:   675254       Rx bytes:    40660264       Lost frames: 9       Tx frame rate [1/s]:    120    122    121       Tx rate [KByte/s]:      7.0    7.1    7.1       Rx frame rate [1/s]:    120    122    121       Rx rate [KByte/s]:      7.0    7.1    7.1       Loss rate [1/s]:          0      0      0       Frame loss [%]:         0.0    0.0    0.0   Distributed clocks:     Reference clock:   Slave 0     DC reference time: 0     Application time:  0                        2000-01-01 00:00:00.000000000 cnc@CNC:~$
I'm a little lost on how to progress from here though. Obviously rod's ethercat-config.xml file is setup for his devices and doesn't load for me. I get the following error report.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.4 Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis.gantry' Machine configuration file is 'gantry.ini' INIFILE=/home/cnc/linuxcnc/configs/sim.axis.gantry/gantry.ini VERSION=1.1 PARAMETER_FILE=sim.var TPMOD= HOMEMOD= TASK=milltask HALUI= DISPLAY=axis COORDINATES=XYZY KINEMATICS=trivkins coordinates=XYZY kinstype=BOTH Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io emc/iotask/ioControl.cc 786: can't load tool table. linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./ethercat.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime Failed to execute SDO download: Input/output error LCEC: slave 0.0: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 06010002) LCEC: failed to configure slave 0.0 sdo 2000:00 Failed to execute SDO download: Input/output error LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06020000) LCEC: failed to configure slave 0.0 sdo 2007:06 Failed to execute SDO download: Input/output error LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x05, size 1, byte0=5, error -5, abort_code 06020000) LCEC: failed to configure slave 0.0 sdo 2007:05 Failed to execute SDO download: Invalid argument LCEC: slave 0.1: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.1 sdo 2000:00 Failed to execute SDO download: Invalid argument LCEC: slave 0.1: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.1 sdo 2007:06 Failed to execute SDO download: Invalid argument LCEC: slave 0.1: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.1 sdo 2011:00 Failed to execute SDO download: Invalid argument LCEC: slave 0.2: Failed to execute SDO download (0x2000:0x00, size 2, byte0=88, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.2 sdo 2000:00 Failed to execute SDO download: Invalid argument LCEC: slave 0.2: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.2 sdo 2007:06 Failed to execute SDO download: Invalid argument LCEC: slave 0.2: Failed to execute SDO download (0x2011:0x00, size 2, byte0=0, error -22, abort_code f67e76d4) LCEC: failed to configure slave 0.2 sdo 2011:00 Failed to register PDO entry: No such file or directory LCEC: master 0 PDO entry registration failed LCEC: failure, clearing config LCEC: exiting LCEC: returning -EINVAL lcec: rtapi_app_main: Invalid argument (-22) ./ethercat.hal:2: waitpid failed /usr/bin/rtapi_app lcec ./ethercat.hal:2: /usr/bin/rtapi_app exited without becoming ready ./ethercat.hal:2: insmod for lcec failed, returned -1 12547 Stopping realtime threads Unloading hal components Note: Using POSIX realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file:    /tmp/linuxcnc_info.txt can be posted to a forum or a web site like:      http://pastebin.com in order to provide information about the linuxcnc system and configuration.                 Date: Thu 23 Oct 2025 12:29:51 AEDT             UTC Date: Thu 23 Oct 2025 01:29:51 UTC         this program: /usr/bin/linuxcnc_info               uptime: 12:29:51 up 1:27, 1 user, load average: 4.59, 4.92, 4.60      lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm             linuxcnc: /usr/bin/linuxcnc                  pwd: /home/cnc/linuxcnc/configs/sim.axis.gantry                 USER: cnc              LOGNAME: cnc                 HOME: /home/cnc               EDITOR:               VISUAL:             LANGUAGE: en_AU:en                 TERM: dumb            COLORTERM:              DISPLAY: :0.0              DESKTOP: lightdm-xsession         display size: 1920x1080 pixels (508x285 millimeters)                 PATH: /usr/bin:/home/cnc/linuxcnc/configs/sim.axis.gantry/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items:          nodename -n: CNC       kernel-name -s: Linux       kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12)           machine -m: x86_64         processor -p: unknown          platform -i: unknown       oper system -o: GNU/Linux /proc items:              cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-rt-amd64 root=UUID=0f3a6e83-8d9a-4590-a5d4-e505f6df4f87 ro quiet           model name: AMD Ryzen 7 5825U with Radeon Graphics                cores: 8              cpu MHz: 3594.461              parport:               serial: Versions:                  gcc: gcc (Debian 12.2.0-14) 12.2.0               python: Python 3.11.2                  git: git version 2.39.5           git commit: NA                  tcl: 8.6                   tk: 8.6                glade: not_in_PATH linuxcnc_var all:      LINUXCNCVERSION: 2.9.4 LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples             REALTIME: /usr/lib/linuxcnc/realtime                  RTS: uspace           HALLIB_DIR: /usr/share/linuxcnc/hallib               PYTHON: /usr/bin/python3 dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name                Version           Architecture Description +++-===================-=================-============-===================================================================== un  linuxcnc            <none>            <none>       (no description available) un  linuxcnc-dev        <none>            <none>       (no description available) un  linuxcnc-doc        <none>            <none>       (no description available) ii  linuxcnc-doc-de     1:2.9.4           all          motion controller for CNC machines and robots (German documentation) ii  linuxcnc-doc-en     1:2.9.4           all          motion controller for CNC machines and robots (English documentation) ii  linuxcnc-doc-es     1:2.9.4           all          motion controller for CNC machines and robots (Spanish documentation) ii  linuxcnc-doc-fr     1:2.9.4           all          motion controller for CNC machines and robots (French documentation) ii  linuxcnc-ethercat   1.40.0.g8a607c0-0 amd64        LinuxCNC EtherCAT HAL driver un  linuxcnc-sim        <none>            <none>       (no description available) un  linuxcnc-sim-dev    <none>            <none>       (no description available) ii  linuxcnc-uspace     1:2.9.4           amd64        motion controller for CNC machines and robots ii  linuxcnc-uspace-dev 1:2.9.4           amd64        PC based motion controller for real-time Linux
1 year 1 week ago #336920 by SPH
I've tried updating the first device in Rodw's .xml file with my drives id's as returned from ethercat-slaves and trimming the other devices out of the file. File is attached.Generates the following error when run.
1 year 1 week ago #336921 by Hakan
Those 2xxx sdo numbers are not universal and probably differ between your drive and rodw's.
Put the output of the command "lcec_configgen" into ethercat-conf.xml.
Modify the master line if needed and look over the naming of pins.
1 year 1 week ago #336922 by SPH
Thanks for the help! I've adjusted the file and get the attached error. Not sure what inputs I'd trim out.
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.4 Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis.gantry' Machine configuration file is 'gantry.ini' INIFILE=/home/cnc/linuxcnc/configs/sim.axis.gantry/gantry.ini VERSION=1.1 PARAMETER_FILE=sim.var TPMOD= HOMEMOD= TASK=milltask HALUI= DISPLAY=axis COORDINATES=XYZY KINEMATICS=trivkins coordinates=XYZY kinstype=BOTH Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io emc/iotask/ioControl.cc 786: can't load tool table. linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./ethercat.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime LCEC: slave 0.D1: FAILURE: FAILURE: more input PDO entries configured than your hardware supports. Axis 1 has 13 PDO entries, vs a configured limit of 8. You will need to edit your XML configuration and either remove some <modParam name="enable*"> entries or increase <modParam name="ciaTxPDOEntryLimit">. Check your CiA 402 slave's hardware manual to determine the correct limit. Enabled features that impact this limit are: - <modParam name="enableActualCurrent" value="true"> - <modParam name="enableActualFollowingError" value="true"> - <modParam name="enableActualTorque" value="true"> - <modParam name="enableErrorCode" value="true"> - <modParam name="enablePositionDemand" value="true"> - <modParam name="enableProbeStatus" value="true"> - <modParam name="enableTorqueDemand" value="true"> - <modParam name="enableVelocityDemand" value="true"> In addition, disabling unneeded CiA 402 modes may help, as some implicitly add additional PDO entries: - <modParam name="enablePP" value="true"> - <modParam name="enablePV" value="true"> - <modParam name="enableCSP" value="true"> - <modParam name="enableCSV" value="true"> - <modParam name="enableCST" value="true"> - <modParam name="enableHM" value="true"> - <modParam name="enableTQ" value="true"> HAL: ERROR: thread 'servo-thread' not found ./ethercat.hal:3: addf failed 17208 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
1 year 1 week ago #336923 by SPH
Thought I'd add that Delta does have a xml file in their downloads section for these drives but I'm not sure if it's useful or not.
1 year 1 week ago - 1 year 1 week ago #336925 by Hakan
Oh I see, it selected the basic-cia402 driver.
Set all those enableXXX modes in the second listing to false
Except enableCSP leave at true.
That xml you found is an esi file, Linuxcnc doesn't use that.
You can find the synchronization modes the drive support, assignactivate items.
That can be helpful. All other needed info is read from the drive.
Last edit: 1 year 1 week ago by Hakan.
Time to create page: 0.260 seconds
