EtherCAT with OMRON R88D-1SN servo drive
  • sparviero
  • sparviero's Avatar Topic Author
  • New Member
  • New Member
24 Oct 2025 18:00 #337078 by sparviero
EtherCAT with OMRON R88D-1SN servo drive was created by sparviero
Hello everyone,
I am a beginner of LinuxCNC but I have collected what i have learned using EtherCAT, BECKHOFF modules and a OMRON R88D-1SN drive. I think it may be useful for others approaching this world. The repository is still incomplete and lacks of many things. Hope in a feedback from everyone and from who is working with the same OMRON drive.
Here is the link to the github page:  linuxcnc-collection
The following user(s) said Thank You: tommylight, Aciera, endian, onceloved
24 Oct 2025 18:38 #337079 by Aciera
Replied by Aciera on topic EtherCAT with OMRON R88D-1SN servo drive
Looks like a fair bit of work has already gone into this. Thanks for sharing.
The following user(s) said Thank You: sparviero
  • sparviero
  • New Member
  • New Member
02 Nov 2025 15:02 #337713 by sparviero
Replied by sparviero on topic EtherCAT with OMRON R88D-1SN servo drive
Hello again,
just a little update. On the repository i have added more information about current configuration but still a lot of work need to be done. Unlikely I have only one motor so i can't scale along 3 axes.
I have also updated a video on YouTube.
Next steps are:
  • resolve joint 0 amplifier fault when toggle machine power. This seems to happen only one time after LinuxCNC opening.
  • run and understand LinuxCNC / HAL Latency Test for a better configuration of LinuxCNC
  • set machine configuration parameters like: encoder resolution, velocity, acceleration, pitch of leadscrew...
  • implement PID control
  • customizing using PyVCP
Time to create page: 0.145 seconds
