ASDA-A2-1521-E parameter list for ethercat com
10 Nov 2025 22:14 #338166 by Beovoxo
Hi all is there a friendly soul out there, that have a parameter file ..? I can´t seem to get the RJ45 ports "online" like i have not made the right setup. i can connect to the drive via usb without any problems.
Best regards
  • Hakan
  • Platinum Member
  • Platinum Member
10 Nov 2025 23:05 #338168 by Hakan
With ethercat master installed it should be to just plug in the network cable, power on and the drive will show up in the "ethercat slaves" list, at least after "ethercat rescan".
If not, make sure the ethercat master is functioning "ethercat master -v" should show a lot of non-zero numbers.
11 Nov 2025 14:27 #338188 by Beovoxo
thx :) i thought the light would be on, and flashing while communicate. i just connected them to the ek1100 and no faults :):)
Time to create page: 0.120 seconds
