- Thank you received: 7
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
- DemonClaW
- Topic Author
11 months 3 weeks ago - 11 months 3 weeks ago #338208
by DemonClaW
Beckhoff Problem with Communication (TwinCAT, LinuxCNC) was created by DemonClaW
Hey Guys,some of you know so much about this Topic so I hope I can find someone in the mood to help me.Im trying to make a CNC 3-Axis on Raspberry PI5 and Beckhoff, the problem is that im completly new in this topic and try to learn as much as possible but i got already stuck in the beginning. EtherCAT works fine and i got the "Koppler" and Cards but if im trying to get them into LinuxCNC like some videos teach the Programm wont start anymore
If i start i get the message: Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO enty registration failed
A friend and myself checked the code 10x, and it seems that the problem starts before. I cant get the EK1100 connected to TwinCat or CodeSYS, too. Whats kind of weird to me because as i said if I try it with the "ethercat slaves" command, it knows The Ek1100 and all Cards
Thanks for everybody who can help me with this and invests some of his time for me
Last edit: 11 months 3 weeks ago by DemonClaW. Reason: Missing Content
11 months 3 weeks ago #338215
Replied by tommylight on topic Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
No double posting.
And fix the tittle to explain what it is about.
Thank you.
Thank you.
The following user(s) said Thank You: DemonClaW
- DemonClaW
- Topic Author
11 months 3 weeks ago #338449
by DemonClaW
Replied by DemonClaW on topic Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Better like that?
11 months 3 weeks ago #338451
Replied by rodw on topic Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
seems like the lcec file in the hal fie has an invalid path. or XML has an invalid path.
- Hakan
- Thank you received: 411
11 months 3 weeks ago #338453
by Hakan
Replied by Hakan on topic Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Only way to know is to have the xml and hal files, the error messages and some lines around them, and the last say 30 lines of the syslog.
11 months 3 weeks ago #338459
Yes, thank you.Better like that?
- DemonClaW
- Topic Author
11 months 2 weeks ago - 11 months 2 weeks ago #338764
by DemonClaW
Ive already tried it on 3 different ways now,
1. A youtube Video from Talla82 (looked awsome how easy it would be....)
2. with the Instructions from you (Forum) @rodw
3. ChatGPT whats kind of ... depressing and for sure wont work
I can hang you the current lcec.conf whitch is the setup for my EK1100 hopefully you can help me correct it
Last edit: 11 months 2 weeks ago by DemonClaW.
- Hakan
11 months 2 weeks ago #338775
by Hakan
What's that? Never seen that before.
Anyway that won't work with lcec_conf, it requires a file in xml format.
Easiest way, I think, is to take the output of the command "lcec_configgen" and put that
in the ethercat-conf.xml file and use that as input to lcec-conf.
Example here to show the structure and syntax of things
github.com/dbraun1981/hal-cia402/tree/main/example
Reference to lcec and lcec_conf
github.com/linuxcnc-ethercat/linuxcnc-ethercat
- DemonClaW
- Topic Author
11 months 2 weeks ago - 11 months 2 weeks ago #338778
by DemonClaW
I didnt see that either, its what i got with my last and frustraded way by using AI.
Before I did the "Thing" above I had this as .xml but that didnt work, too
I have started by doing it exactly like this :
- Hakan
11 months 2 weeks ago #338782
by Hakan
Best if you show
Time to create page: 0.069 seconds
