an CIA402 Stepper/Servo as Spindle
- Red_D85
- Topic Author
11 months 2 weeks ago #338794
by Red_D85
an CIA402 Stepper/Servo as Spindle was created by Red_D85
Hallo at all
how can i get an CIA 402 Ethercat stepper work as spindle? I had 3axes (X Y Z) that works. Anybody can help?
Greetings
Greetings
- Hakan
- Thank you received: 405
11 months 2 weeks ago #338804
by Hakan
Replied by Hakan on topic an CIA402 Stepper/Servo as Spindle
You can use this component instead of the standard cia402 component.
github.com/MetalMusings/cia402pv
The drive uses PV (Profile Velocity) mode which is more suitable
for a spindle motor as it has its own speed ramp up and down.
- Red_D85
- Topic Author
11 months 2 weeks ago #338807
by Red_D85
Replied by Red_D85 on topic an CIA402 Stepper/Servo as Spindle
Hi Hakan
thank you
What should the whole thing look like in the hall and ini? is there an sample?
thank you
- Hakan
11 months 2 weeks ago #338808
by Hakan
Yes there is an example. Two normal stepper drives and one stepper motor spindle.
In the example directory.
The following user(s) said Thank You: Red_D85, COFHAL
- Red_D85
- Topic Author
11 months 2 weeks ago #339131
by Red_D85
Hello Hakan
can i had 2 instances Cia402
Cia402dBraun for xyz and cia402pv for spindle? did you know that?
- Hakan
11 months 2 weeks ago - 11 months 2 weeks ago #339144
by Hakan
Yes, that's what I have in the example.
It might work with the cia402pv instead of the standard cia402 also in csp mode.
But I'm not sure, the goal with that component was to add PV, and I may have
broken csp. Not that I meant to, but I didn't check thoroughly.
Also the pv-mode=true and csp-mode=true doesn't work well together,
there should really be a new logic like op-mode=3 (for csp-mode)
Last edit: 11 months 2 weeks ago by Hakan.
Time to create page: 0.310 seconds
