Servotronix Ethercat problem
- Neiji_msk
26 Nov 2025 13:23 #339242
by Neiji_msk
Servotronix Ethercat problem was created by Neiji_msk
Hello everyone, I have a small problem. I have three VEICHI drives connected via Ethercat in my system. My task was to connect a fourth driver to them, but from a different manufacturer (Servotronix CDHD2S). I purchased this driver, and everything works fine with the PC. Then I connected the driver to the common system with the other drivers via Ethercat, configured it, and added vid and pid. As a result, Linux CNC starts, but the driver hangs in an error and does not switch from PREOP to OP. Please advise what the problem might be. I am attaching my configurations and the xml from the driver manufacturer.
- Hakan
- Thank you received: 459
26 Nov 2025 13:49 #339244
by Hakan
Replied by Hakan on topic Servotronix Ethercat problem
Can you please show the last say 30 lines from the syslog after you tried to start linuxcnc.
The ethercat master writes errors there
Output of "sudo dmesg | tail -30"
The following user(s) said Thank You: Rookie0
- Neiji_msk
26 Nov 2025 15:01 #339247
by Neiji_msk
Replied by Neiji_msk on topic Servotronix Ethercat problem
My Linux runs fine. It's just that the driver doesn't switch to enable mode, but the other three axes work. I think the problem might be with vid and pid.
Time to create page: 0.532 seconds
