Machine fails to get past G1 "spindle-at-speed" issue EtherCAT spindle
29 Nov 2025 16:10 #339455 by Will_cnc
Hi everyone,I’ve recently finished mounting my machine to its base and tidying up the wiring, so I decided to try running a quick program to see if everything was working properly.Machine Configuration:
  • Controller: Raspberry Pi 5
  • Servos: 3 × Leadshine EL8 servo drives with 400 W motors (EtherCAT)
  • Spindle: 1 kW StepperOnline drive (EtherCAT)
The program starts fine, but the machine seems to get stuck at the first G1 command.After doing some reading, it looks like this could be related to the “spindle-at-speed” signal in the HAL configuration.Because I’m using EtherCAT, I’m not sure where this needs to be handled:
Should the spindle-at-speed signal be configured in the HAL file, or Is it something that needs to be set up in the .comp file for the EtherCAT drive?
Any guidance or examples on how to handle this signal within an EtherCAT setup would be really appreciated. when the spindle is running currently I am having no feedback from the drive to record the actual speed ?
29 Nov 2025 16:31 - 29 Nov 2025 16:31 #339457 by Hakan
I seem to have made a mistake in the cia402pv component with the stat-at-speed pin..
I'll look at that tomorrow. If you just want to mill you can comment out the spindle-at-speed signal and
setp Spindle.0.at-speed 1
Last edit: 29 Nov 2025 16:31 by Hakan.
The following user(s) said Thank You: Will_cnc
29 Nov 2025 16:53 #339458 by Will_cnc
Hi Hakan
thanks for your help , I'm using the cia402pv component you put together, I can't seem to get the drive to feed back the velocity of the motor could this maybe be another issue ?
29 Nov 2025 17:17 #339459 by Hakan
Not the same, stat-at-speed looks for two bits in the statusword from the drive.
There is a genuine mistake made there.
But actual speed should work nevertheless, I'll take a look at that also tomorrow.
Do you see any actual speed from the lcec.0 component?
30 Nov 2025 03:12 #339479 by Hakan
I pushed an update for stat-at-speed pin.
Logic was reversed :), now it works in csv and pv mode. Should work is best to say.
The cs401pv module just scales and forwards the actual-velocity from the drive.
There isn't much I can do if the drive doesn't provide actual velocity in pv mode.
Look at available pdos and see if you find something that looks like actual velocity?
The following user(s) said Thank You: andypugh, tommylight, besriworld
30 Nov 2025 09:43 #339498 by Will_cnc
Hi
Thanks for looking into the issue
How do I go about updating the file I have to work ?
30 Nov 2025 11:10 #339506 by Hakan
Get the file with git or copy from the browser
github.com/MetalMusings/cia402pv/blob/master/cia402pv.comp
sudo halcompile --install cia402pv.comp
Time to create page: 0.235 seconds
