Ethercat Leadshine L6N Gantry XYYZ Config
02 Dec 2025 18:24 #339659 by dcsilvias13
Ethercat Leadshine L6N Gantry XYYZ Config was created by dcsilvias13
Hello, I wanted to add my configuration files to help some of you.  I know many of you have been like me scowering around for answers looking up every possible key word to get your system up and running.  Now I don't have a spindle hooked up yet this is just to get X Y Y2 Z up and running.  There was some configuration in the Leadshine Parameters as well that had to be made. 1 of those is Parameter 6092 (0x01) had to change to 10000, not sure why, but it just worked.  Also make sure all the slaves correspond as well with the PDO's. Just remember this is very basic in what I had to do to get the servos moving and running with one home/limit switch per AXIS.
File Name: axis.ini
File Size:6 KB
File Name: ethercat-conf.xml
File Size:4 KB
File Name: EtherCatv1.2.hal
File Size:5 KB
  • IndeeSales
  • IndeeSales's Avatar
  • Visitor
  • Visitor
29 Jan 2026 21:05 #342175 by IndeeSales
Replied by IndeeSales on topic Ethercat Leadshine L6N Gantry XYYZ Config
Could you post your CoreDC.hal file? I am trying to setup a gantry router with steppersonline ethercat drives. and have hit a wall with this setup
30 Jan 2026 15:22 #342216 by dcsilvias13
Replied by dcsilvias13 on topic Ethercat Leadshine L6N Gantry XYYZ Config
I am pretty sure I didn't make any changes to the .coreDC file.  What troubles are you running into? Ill post it anyway in case I did.
File Name: coreDC.hal
File Size:2 KB
Time to create page: 0.421 seconds
