Config 2 ethercat ports?
- heaven
- Thank you received: 3
08 Dec 2025 04:41 #339847
by heaven
Config 2 ethercat ports? was created by heaven
My PC has two Ethernet ports. I want to use port 1 to connect to devices A, B, and C, and port 2 to connect to devices D, E, and F because they are in separate locations. Is it possible to configure two EtherCAT ports?
- jc2ktr
- Thank you received: 17
08 Dec 2025 04:49 - 08 Dec 2025 05:06 #339848
by jc2ktr
Replied by jc2ktr on topic Config 2 ethercat ports?
Yes, you add a second master in your /etc/ethercat.conf
There is already a line:
# The MASTER<X>_DEVICE variables also determine, how many masters will be
# created: A non-empty variable MASTER0_DEVICE will create one master, adding a
# non-empty variable MASTER1_DEVICE will create a second master, and so on.
MASTER0_DEVICE="eno0"
MASTER1_DEVICE="eno1 or mac adress"
Then you can add a second master in your ethercat-conf.xml
<master idx="1" appTimePeriod="1000000" refClockSyncCycles="5">
And that's it.
I had testet it with 2 Nic's not long ago
It's working fine.
Greetings Sven
And that's it.
It's working fine.
Greetings Sven
Last edit: 08 Dec 2025 05:06 by jc2ktr. Reason: Fixed typos
The following user(s) said Thank You: endian, Rookie0, heaven
- endian
- Thank you received: 134
08 Dec 2025 05:39 #339849
by endian
Replied by endian on topic Config 2 ethercat ports?
and then how will you specify the .hal file for separate masters?
there will be more lcec. instances?
do anybody have working config?
- jc2ktr
08 Dec 2025 06:49 #339851
by jc2ktr
You get after start another lcec.1. instances with your pins.
I can provide a config later this day.
Greets sven
Greets sven
The following user(s) said Thank You: endian, heaven
- jc2ktr
08 Dec 2025 11:16 - 08 Dec 2025 11:18 #339858
by jc2ktr
This is my Config which should Work.
It´s a small setup in my Shop on my Workbench. It is for tinkering with, EtherCAT & LinuxCNC.
The PC is an old Siemens Microbox PC with 3 Ethernet Ports.
Last edit: 08 Dec 2025 11:18 by jc2ktr. Reason: Text Added
The following user(s) said Thank You: endian, onceloved, heaven
Time to create page: 0.231 seconds
