Can't get EL4001 to work - all other devices work
13 Dec 2025 23:48 #340079 by dfarnainekl
Hello,
I added an EL4001 analog output terminal to a system with a few other Beckhoff terminals, which is otherwise fully working.
Like the other terminals, the EL4001 shows up with "ethercat slaves" and this as well as its status LED shows it's in the OP state.
I added it to the ethercat-config.xml like the other nodes:<slave idx="4" type="EL4001" name="spindleSpeed"/>
I also tried setting it up manually like here .
Unfortunately, I can't get any output voltage out of it (other than zero) using the pins as documented  (I set the pins using halcmd and verified with Halscope). As mentioned, all other Ethercat devices (mostly Beckhoff) work without issues. I also tried changing the order of the Beckhoff terminals, but that didn't help (as expected).
Does anyone have any idea what could be the issue here, or what I can do to further debug this?
14 Dec 2025 03:18 #340083 by Hakan
Verify that the slave has the entered PDOs with "ethercat -p 2 pdos"
Check syslog for any messages, last lines of "sudo dmesg"
If that doesn't give anything, add debug messages "ethercat debug 1"
 restart ethercat master, start linuxcnc and check syslog again for any helpful output.
17 Dec 2025 12:12 #340239 by dfarnainekl
Replied by dfarnainekl on topic Can't get EL4001 to work - all other devices work
Thanks Hakan for the inputs.
After not finding any obvious issues using your suggestion, I did what I should have done in the first place and used TwinCAT to test the terminal.
And as it turns out, the terminal seems to be the issue despite being sold as working, I can't get it to output anything with TwinCAT either.
So I will get a new one and try again.
Time to create page: 0.083 seconds
