Unsupported access to an object
17 Dec 2025 16:01 #340244 by nanowhat
Unsupported access to an object was created by nanowhat
I'm trying to change a drive's home offset via SDO (can't be done via PDO). Executing the command 'ethercat download -p2 -t int32 0x607C 0' returns "SDO transfer aborted with code 0x06010000: unsupported access to an object"
Obviously it doesn't work. Why doesn't it work?
Everything I've found online simply parrots the failure code and doesn't say why.
17 Dec 2025 16:42 - 17 Dec 2025 16:43 #340246 by Hakan
Replied by Hakan on topic Unsupported access to an object
From the ethercat docs it looks like i should work. However I always use this syntax
ethercat -p 2 download 0x607c 0 0.
Actually what I always do first is to see which values the sdo has
ethercat -p 2 upload 0x607c 0
0x00000000 0
And then do the download.
ethercat -p 2 download 0x607c 0 1
to set it to 1.
Last edit: 17 Dec 2025 16:43 by Hakan.
The following user(s) said Thank You: nanowhat
17 Dec 2025 18:44 #340250 by nanowhat
Replied by nanowhat on topic Unsupported access to an object
That did it. I didn't specify a subindex, since the drive manual said there isn't one for 0x607C. However, at least in this case, ethercat download doesn't work without it.
'ethercat download -p2 -t int32 0x607C 0 35951' works as expected.
Time to create page: 0.184 seconds
