leadshine R3EC
22 Dec 2025 15:01 #340398 by Ahmed.emara
leadshine R3EC was created by Ahmed.emara
hello guys
i really need help with configuring R3EC IO coupler + R3 1600 DI + R3 0016-P DO ,to my etherCAT system,
i wrote XML file but when i check the status of the slaves all the drivers are in OP mode except the R3EC is in SAFEOP and it does not switch to OP mode,
here is the XML section for the R3EC i used :
<slave idx="6" type="generic" vid="0x00004321" pid="0x61400025" configPdos="true">
<!-- SM2: Outputs -->
<syncManager idx="2" dir="out">
<pdo idx="0x7000">
<pdoEntry idx="0x7000" subIdx="0x01" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="do-01" halType="bit"/>
<complexEntry bitLen="1" halPin="do-02" halType="bit"/>
<complexEntry bitLen="1" halPin="do-03" halType="bit"/>
<complexEntry bitLen="1" halPin="do-04" halType="bit"/>
<complexEntry bitLen="1" halPin="do-05" halType="bit"/>
<complexEntry bitLen="1" halPin="do-06" halType="bit"/>
<complexEntry bitLen="1" halPin="do-07" halType="bit"/>
<complexEntry bitLen="1" halPin="do-08" halType="bit"/>
<complexEntry bitLen="1" halPin="do-09" halType="bit"/>
<complexEntry bitLen="1" halPin="do-10" halType="bit"/>
<complexEntry bitLen="1" halPin="do-11" halType="bit"/>
<complexEntry bitLen="1" halPin="do-12" halType="bit"/>
<complexEntry bitLen="1" halPin="do-13" halType="bit"/>
<complexEntry bitLen="1" halPin="do-14" halType="bit"/>
<complexEntry bitLen="1" halPin="do-15" halType="bit"/>
<complexEntry bitLen="1" halPin="do-16" halType="bit"/>
</pdoEntry>
</pdo>
</syncManager>
<!-- SM3: Inputs -->
<syncManager idx="3" dir="in">
<pdo idx="0x6000">
<pdoEntry idx="0x6000" subIdx="0x01" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="di-01" halType="bit"/>
<complexEntry bitLen="1" halPin="di-02" halType="bit"/>
<complexEntry bitLen="1" halPin="di-03" halType="bit"/>
<complexEntry bitLen="1" halPin="di-04" halType="bit"/>
<complexEntry bitLen="1" halPin="di-05" halType="bit"/>
<complexEntry bitLen="1" halPin="di-06" halType="bit"/>
<complexEntry bitLen="1" halPin="di-07" halType="bit"/>
<complexEntry bitLen="1" halPin="di-08" halType="bit"/>
<complexEntry bitLen="1" halPin="di-09" halType="bit"/>
<complexEntry bitLen="1" halPin="di-10" halType="bit"/>
<complexEntry bitLen="1" halPin="di-11" halType="bit"/>
<complexEntry bitLen="1" halPin="di-12" halType="bit"/>
<complexEntry bitLen="1" halPin="di-13" halType="bit"/>
<complexEntry bitLen="1" halPin="di-14" halType="bit"/>
<complexEntry bitLen="1" halPin="di-15" halType="bit"/>
<complexEntry bitLen="1" halPin="di-16" halType="bit"/>
</pdoEntry>
</pdo>
</syncManager>
</slave>
i appreciate your help guys i have been stuck with this problem since two weeks!
22 Dec 2025 15:12 #340399 by Hakan
Replied by Hakan on topic leadshine R3EC
Check the last say 10-20 lines of the output of "sudo dmesg".The ethercat master
always tells why (in a not so obvious way) why slaves won't go OP.
25 Dec 2025 18:03 #340501 by Ahmed.emara
Replied by Ahmed.emara on topic leadshine R3EC
My problem. Is in PDO mapping, i was able to configure how to switch the IO module to OP state by using sdoconfig in XML to set some SDO to be able to switch to OP state, now my problem is with PDO mapping section, the manual says PDO 6000 is for inputs and PDO 7000 for outputs, when i ran sudo ethercat -p 5 pdos, i couldn’t find these PDOS
