- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- StepperOnline A6 Servos: Sync Error when closing LinuxCNC
- wildcam45
16 Jan 2026 14:29 #341452
by wildcam45
StepperOnline A6 Servos: Sync Error when closing LinuxCNC was created by wildcam45
Hi
I got tree Stepperonline A6 servo motors up and running in XYZ mode using the attached files. When I close LinuxCNC, however, all three drivers show error ErC 1.1, i.e. Sync Error. When I start LinuxCNC again, the errors disappear. So it is not a big deal, but it is ugly to see that the program was not terminated in a decent way.
I suppose that there must be some appropriate commands in the shutdown.hal file. I tried a lot of things, but none of them worked. Dies anyone know what to put in the shutdown.hal file to prevent the sync error or is there an other way to prevent this error?
- Hakan
- Thank you received: 459
22 Jan 2026 10:22 #341686
by Hakan
Replied by Hakan on topic StepperOnline A6 Servos: Sync Error when closing LinuxCNC
You can try with the syncToRefClock optionor if you have an old version of lcec, a minus sign
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1" syncToRefClock="true"><master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
- EtherCAT
Time to create page: 0.354 seconds
