Lichuan 4 axis stepper need help-
9 months 1 week ago #341831 by Hakan
There was a question on that drive before in the forum, was that of any help?
Not exactly the problem you have if I recall right, but anyway.
Hoping to avoid looking at all supplied files hehe.
9 months 1 week ago #341832 by rodw
Maybe not so Lucky. I did find a thread on a 2 axis drive that had the same issue but it was never resolved.  I think this is  a deeper problem but don't know why. At least I have the config sorted out and working BUT....
Joint 0 is working perfectly now but Joints 1, 2 and 3 do nothing. The statusword etc are not updating so I am beginning to think this is an issue with our drivers etc. Is it because there is not a slave for every drive? Maybe there is something to enable the later drives so will dig.
I've updated some files attached here.
9 months 1 week ago #341846 by Hakan
Some ideas.
Check syslog: "sudo dmesg | tail -30"
Are pdos configurable? Check the esi/xml file. Adjust configPdos if needed.
It's one slave. Config looks ok in principle.
Try with only the seconds drive, remove 0x1600, 0x1620, 0x1630, same for Rxpdos.
9 months 1 week ago #341854 by rodw
yeh, I looked at dmesg.
I did a brief review. It looks like cia402 is getting an enable signal and something goes awry before the drives come on line
I've never liked the current cia402 component source code as its really too hard to debug and does not follow a cia402 state machine.
It also no longer works properly for homing without modification with the advent of homecomps!
So I'm going to try to rewrite it
The following user(s) said Thank You: NWE
9 months 1 week ago - 9 months 1 week ago #341857 by Hakan
Well, I think it follows the state diagram up to the point of operation
But for sure it isn't perfect. I have noticed multiple homing components around even if I don't use it myself.
Can you add support for PV (Profile Velocity) while you are at it? I made a quick fix for that.
PV is suitable for spindle mode.
You should be able to transition states manually, in halshow for example, using controlword and check statusword.
Maybe that can give a clue to why it seems so grumpy.
Last edit: 9 months 1 week ago by Hakan.
9 months 1 week ago #341874 by rodw
I gave some detailed instructions to Grok last night then slept like a baby.. I always wanted to use a C union to break out status word etc into  bits starts to make it readable.
Time to create page: 0.151 seconds
