CiA 402 Folder Missing
8 months 1 week ago #343337 by andrax
Replied by andrax on topic CiA 402 Folder Missing
The forum was unavailable all weekend.
I checked your configuration.
You are using my config and have deleted the modules in master idx="1" in the XML.
Accordingly, you must also delete the corresponding links in the hal.
These are all links in the “# Switches” section.
If you don't have a handwheel, you can remove this:
loadusr -W xhc-whb04b-6 -HsfB and all MDI_COMMAND in the .ini
However, the error ./cia402-example.hal:63: parameter or pin ‘joint.0.request-cia-homing’ not found
is strange. The corresponding pins are present.
Can you upload the complete error log next time?
PS: setp iocontrol.0.emc-enable-in 1 System without emergency stop?
Very dangerous.
8 months 1 week ago - 8 months 1 week ago #343418 by Konstantin
Replied by Konstantin on topic CiA 402 Folder Missing
Hello,
the forum was indeed down during the weekend, no problem. On the first run of your configuration I forgot to remove the limit switches, the hand wheel and the MDI commands. Then I removed all of them but still the same result. By the way, I also switched the HOMING_METHOD and DISPLAY in the .ini file.
About the emergency stop - the motors are not mounted on the machine, they are on a stand and there is no danger of hurting anyone. Thank you for pointing it out.
Attached is the entire report when I run the LinuxCNC and the edited configuration files.
Last edit: 8 months 1 week ago by Konstantin.
8 months 1 week ago #343451 by andrax
Very interesting.
I don't see any errors in the configuration.
Can you please post the following outputs?
ethercat master
ethercat slaves
sudo dmesg
8 months 1 week ago #343478 by Konstantin
Hello,
attached are the requested outputs and I added PDOs and SDOs outputs as well.
8 months 1 week ago #343493 by 3404gerber
Replied by 3404gerber on topic CiA 402 Folder Missing
I have no experience with CiA homecomp, but if I have a look at the comp source code here , I see that it creates a "joint.%d.request-custom-homing", jno" pin. Could the name be your problem?
Cheers,
Luca
8 months 6 days ago #343547 by andrax
You have a lot of synchronization errors.
What kind of cable are you using?
What is your topology?
Do you have EMC problems?
[70592.094690] EtherCAT ERROR 0-0: AL status message 0x001A: “Synchronization error”.
Time to create page: 0.071 seconds
