Hi all,I spent some time reading through the existing code and examples (
, the Leadshine EL8 example, and rodw’s
), plus the available documentation (Yaskawa EtherCAT, some A6/Lichuan docs, and the CiA-402 profile). I don’t have this hardware on my bench, so this is a code/doc-based perspective.One thing that stands out is that the older approaches (
, and the EL8 example) all implicitly assume that LinuxCNC remains the “owner” of the position loop all the time. That works well in modes where LinuxCNC generates the trajectory (CSP/PP/etc.), but it becomes conceptually fragile when the drive performs
internal homing and moves on its own. In those cases, the drive is effectively autonomous for a while, and LinuxCNC still tries to reconcile
vs
, which is where the following-error / desync problems come from. The EL8 example solves this pragmatically for that specific drive, but it’s still a drive-specific adaptation rather than a generic model.What I think is the important architectural step in rodw’s
is that it explicitly acknowledges this: during CiA-402 internal homing, the drive is not under LinuxCNC’s trajectory control. The component tries to
temporarily decouple LinuxCNC from the position loop (by keeping
in sync with
) while the drive is homing, and then re-synchronize afterwards. That feels like the right direction conceptually, and it’s a step beyond just adapting one specific drive.Where it still seems incomplete (and this matches Andrax’s point) is robustness: today the logic mainly focuses on “start homing” and “target reached”, but there is no explicit, defensive state machine with timeouts, start/progress checks, and clear fault paths. For a truly
generic solution that should also work with obscure or poorly documented CiA-402 drives, it probably needs to be more watchdog- and state-driven, and rely only on the minimal, reasonably guaranteed signals (state transitions, mode display, position change, target reached, fault), rather than assuming specific vendor bit semantics.So, from my point of view, the real problem is not “making it work for A6” or any single brand, but defining a LinuxCNC-centred homing flow where:
- LinuxCNC explicitly steps out of the position-control role during internal homing,
- the process is supervised by a small, defensive state machine with timeouts and error paths,
- and then LinuxCNC is cleanly re-attached to the position loop once the drive reports homing done.
This is all based on reading the code and docs, not on hardware testing, but it seems like rodw’s work is already addressing the
right architectural issue, and the next step is mostly about making that flow robust and generic rather than vendor-specific.
