El5101 Config
- rock861261
25 Mar 2026 04:00 #344695
by rock861261
Replied by rock861261 on topic El5101 Config
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
loadrt ddt names=spindle-v
loadrt mult2 names=rpm-calc
loadrt near names=spindle-at-speed
loadrt lowpass names=spindle-filter
addf rpm-calc servo-thread
addf spindle-at-speed servo-thread
addf spindle-v servo-thread
addf spindle-filter servo-thread
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
setp lcec.0.El5101.enc-pos-scale 2000
net spindle-pos-fb lcec.0.El5101.enc-pos => spindle-v.in => spindle.0.revs
setp rpm-calc.in1 60
net spindle-rps spindle-v.out => rpm-calc.in0
setp spindle-filter.gain 0.1
net spindle-rpm-raw rpm-calc.out => spindle-filter.in
net spindle-rpm-fb spindle-filter.out => spindle.0.speed-in
setp spindle-at-speed.scale 1.1
setp spindle-at-speed.difference 10
net spindle-vel-cmd spindle.0.speed-out => spindle-at-speed.in1
net spindle-rpm-fb => spindle-at-speed.in2
net spindle-at-speed-sig spindle-at-speed.out => spindle.0.at-speed
net spindle-index-enable lcec.0.El5101.enc-index-c-enable => spindle.0.index-enable
net spindle-rpm-fb => pyvcp.spindle-speed
loadrt lcec
- rock861261
25 Mar 2026 04:11 #344696
by rock861261
Seems to all be working correctly open to any additional inputs
- Hakan
- Thank you received: 454
25 Mar 2026 17:01 #344728
by Hakan
Replied by Hakan on topic El5101 Config
One would like to have a speed output from the drive but there isn't one.
Should be possible to get rps or rpm in the frequency output
by setting proper scaling factor in frequency-scale.
Have not tried it, though.
- Thank you received: 4150
25 Mar 2026 20:34 #344736
Replied by rodw on topic El5101 Config
Should be possibleOne would like to have a speed output from the drive but there isn't one.
65 float OUT 0 lcec.0.El5101.enc-frequency
65 float I/O 0.05 lcec.0.El5101.enc-frequency-scalePlease Log in or Create an account to join the conversation.
- rock861261
26 Mar 2026 03:07 #344750
by rock861261
doesnt enc-pos provide an accurate speed.
26 Mar 2026 07:27 #344752
I'm not sure on that. pos = position so it implies reading a linear scale when you have a spindle, you want to measure RPM or RPS which a frequency resolves to with appropriate scaling.
- Hakan
26 Mar 2026 07:50 - 26 Mar 2026 07:54 #344754
by Hakan
pos is of course the number of rotations since zeroing on index. This is the main driver for
the synchronized move, the z-axis is being forced to follow pos.
Rotational speed isn't mandatory, but convenient to have.
You use rotational speed for the at-speed pin and is displayed in the gui.
I guess enc-frequency-scale should be set to 1/2000, so 0.0005, for rps.
For rpm 1/(2000*60) = 8.333333e-6.
Last edit: 26 Mar 2026 07:54 by Hakan.
Time to create page: 0.094 seconds
