El5101 Config
7 months 1 week ago #344728 by Hakan
Replied by Hakan on topic El5101 Config
One would like to have a speed output from the drive but there isn't one.
Should be possible to get rps or rpm in the frequency output
by setting proper scaling factor in frequency-scale.
Have not tried it, though.
7 months 1 week ago #344736 by rodw
Replied by rodw on topic El5101 Config
Should be possible
    65  float OUT             0  lcec.0.El5101.enc-frequency     65  float I/O          0.05  lcec.0.El5101.enc-frequency-scale
7 months 6 days ago #344750 by rock861261
Replied by rock861261 on topic El5101 Config
doesnt enc-pos provide an accurate speed.
7 months 6 days ago #344752 by rodw
I'm not sure on that. pos = position so it implies reading a linear scale when you have a spindle, you want to measure RPM or RPS which a frequency resolves to with appropriate scaling.
7 months 6 days ago - 7 months 6 days ago #344754 by Hakan
pos is of course the number of rotations since zeroing on index. This is the main driver for
the synchronized move, the z-axis is being forced to follow pos.
Rotational speed isn't mandatory, but convenient to have.
You use rotational speed for the at-speed pin and is displayed in the gui.
I guess enc-frequency-scale should be set to 1/2000, so 0.0005, for rps.
For rpm 1/(2000*60) = 8.333333e-6.
Last edit: 7 months 6 days ago by Hakan.
Time to create page: 0.111 seconds
