Homing not works immediatelly after launch Linuxcnc
08 Mar 2026 20:23 - 08 Mar 2026 20:25 #344041 by tuxcnc
Short description:
Machine is equipped with integrated ethercat servosteppers, homing by Linuxcnc, not driver internally.
Every work fine but not first homing.
When I perform homing immediatelly after launch Linuxcnc I get some errors, mostly position error.
When I wait several seconds, for the DRO values changed, homing go normally.
It is my first machine with real position feedback and I have no idea what is the reason.
This is not gmoccapy problem, axis works the same.
Last edit: 08 Mar 2026 20:25 by tuxcnc. Reason: No video
  • tiagounderground
  • Junior Member
  • Junior Member
09 Mar 2026 11:57 #344054 by tiagounderground
Replied by tiagounderground on topic Homing not works immediatelly after launch Linuxcnc
probably is the time to the drivers to reach the op state. in my machine i lock the enable button with the op state from the servos
The following user(s) said Thank You: tuxcnc
09 Mar 2026 18:33 #344064 by tuxcnc
Thanks.
The problem was more complex, but you drived me to good way.
I found that the lines in my hal file like <net x-modes-of-operation  cia402.0.opmode => lcec.0.X.opmode> not always works, and sometimes op state never changes to "operational".
Fortunatelly I never use other opmodes than 8, and I can set these permanently.
I added to my halfile code as bellow, and it seems work properly.
loadrt logic names=oper-sum personality=0x103
addf oper-sum                 servo-thread
#  Set opmode permanently
setp lcec.0.X.opmode 8
setp lcec.0.Y.opmode 8
setp lcec.0.Z.opmode 8
#  Check lcec operational
net oper-x         lcec.0.X.slave-state-op   =>     oper-sum.in-00
net oper-y         lcec.0.Y.slave-state-op   =>     oper-sum.in-01
net oper-z         lcec.0.Z.slave-state-op   =>     oper-sum.in-02
net oper-sum-out   oper-sum.and              =>     iocontrol.0.emc-enable-in
(It is ability to use more inputs in the logic hal component.)
