Ethercat Setup help needed for beginner
29 Mar 2026 15:59 #344919 by Spezidrohne
Replied by Spezidrohne on topic Ethercat Setup help needed for beginner
That sounds promising... @andrax
To the folllwing error: fault on my side. The servo was set too soft, and when decelerating there was too much play. Set it a bit harder and now it works.
Mesa card arrives tomorow. Gonna try my best.
29 Mar 2026 17:30 - 29 Mar 2026 17:36 #344920 by Hakan
Replied by Hakan on topic Ethercat Setup help needed for beginner
When you have come this far with EtherCAT you can just keep on going.
No point in switching to Mesa now. Unless you want a Mesa system of course.
Last edit: 29 Mar 2026 17:36 by Hakan.
29 Mar 2026 19:37 - 29 Mar 2026 19:42 #344926 by Spezidrohne
Mesa for my i/o, as i dont have any ethercat 24v i/o. As there might be glass scales in the future, not sure yet. But for general i/o as a jogwheel, pneumatics, Buttons etc. And for spindle vfd. Run, dir, pwm... Mesa cheaper than endless Beckhoff units.
Last edit: 29 Mar 2026 19:42 by Spezidrohne.
29 Mar 2026 20:47 #344929 by rodw
Replied by rodw on topic Ethercat Setup help needed for beginner
Many people look for used  beckhoff modules on eBay.
I just got this working for testing yesterday
www.aliexpress.com/item/1005005340849270.html
It is documented (including manuals)  on the forum here.
It seems to include all I/O you need. It even has 0-10 volt input for plasma torch voltage and 0-10 volt output for spindle. It would be interesting to get the RS485 modbus working to control the spindle VFD but that might be asking too much....
The following user(s) said Thank You: m3chanist, NWE
29 Mar 2026 20:57 #344930 by Hakan
No problem to have both EtherCAT and Mesa. Two network adapters.
You possibly have some IO on the servo drives if you look.
See if you can run the vfd on Modbus, saves alot of IO and get a lot of functionality.
30 Mar 2026 07:03 #344942 by Spezidrohne
It is an older 15kw Tosvert that i repaired some time ago, dont think its in the modbus era. So traditional i/o it is. The servo drives only have 2-3inputs for internal use, like fault reset, homing switch and e-stop.
01 Apr 2026 22:16 - 01 Apr 2026 22:19 #345035 by SwitchWitch
Replied by SwitchWitch on topic Ethercat Setup help needed for beginner
Normally it should be much cheaper to use Beckhoff Interfaces as long as you buy them cheap from ebay or kleinanzeigen (here in germany). This is one of the main benefits of an ethercat setup.
Last edit: 01 Apr 2026 22:19 by SwitchWitch.
02 Apr 2026 16:56 #345067 by andrax
Replied by andrax on topic Ethercat Setup help needed for beginner
A servo of this size is not a toy.
The “Servo On” or “Enable” signal comes from the controller (PLC / lcnc).
The emergency stop and limit switches are hardwired.
03 Apr 2026 06:24 #345097 by NWE
Replied by NWE on topic Ethercat Setup help needed for beginner
I used to do that a lot. Sometimes certain Beckhoff models I wanted were not available from ebay or seemingly anywhere else. A while back I contacted Beckhoff, asking them what distributor they suggest I buy from. They said they sell direct.
Now I mostly buy direct from Beckhoff. I discovered some new parts I had bought from ebay were more expensive on ebay than they were direct from Beckhoff.
04 Apr 2026 04:00 #345139 by rodw
Yes, it certainly pays to get a quote from Beckhoff first. Some of their modules are really cheap and others like encoders 5151 etc al are expensive here in Australia.
The following user(s) said Thank You: NWE
Time to create page: 0.123 seconds
