Ethercat Setup help needed for beginner
7 months 3 days ago #344930 by Hakan
No problem to have both EtherCAT and Mesa. Two network adapters.
You possibly have some IO on the servo drives if you look.
See if you can run the vfd on Modbus, saves alot of IO and get a lot of functionality.
7 months 2 days ago #344942 by Spezidrohne
It is an older 15kw Tosvert that i repaired some time ago, dont think its in the modbus era. So traditional i/o it is. The servo drives only have 2-3inputs for internal use, like fault reset, homing switch and e-stop.
7 months 2 hours ago - 7 months 1 hour ago #345035 by SwitchWitch
Normally it should be much cheaper to use Beckhoff Interfaces as long as you buy them cheap from ebay or kleinanzeigen (here in germany). This is one of the main benefits of an ethercat setup.
Last edit: 7 months 1 hour ago by SwitchWitch.
6 months 4 weeks ago #345067 by andrax
A servo of this size is not a toy.
The “Servo On” or “Enable” signal comes from the controller (PLC / lcnc).
The emergency stop and limit switches are hardwired.
6 months 4 weeks ago #345097 by NWE
Many people look for used  beckhoff modules on eBay.
I used to do that a lot. Sometimes certain Beckhoff models I wanted were not available from ebay or seemingly anywhere else. A while back I contacted Beckhoff, asking them what distributor they suggest I buy from. They said they sell direct. image missing /media/kunena/emoticons/smile.png
Now I mostly buy direct from Beckhoff. I discovered some new parts I had bought from ebay were more expensive on ebay than they were direct from Beckhoff.
6 months 4 weeks ago #345139 by rodw
Yes, it certainly pays to get a quote from Beckhoff first. Some of their modules are really cheap and others like encoders 5151 etc al are expensive here in Australia.
The following user(s) said Thank You: NWE
