- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- CiA402 framework for LinuxCNC (follow-up: runnable + simulation + easier debuggi
- Marcos DC
- Thank you received: 47
29 Mar 2026 19:42 - 29 Mar 2026 19:49 #344937
by Marcos DC
CiA402 framework for LinuxCNC (follow-up: runnable + simulation + easier debuggi was created by Marcos DC
was struggling with the forum editor formatting, so the first post didn’t come out right.
Last edit: 29 Mar 2026 19:49 by Marcos DC.
- Marcos DC
29 Mar 2026 19:47 #344938
by Marcos DC
Replied by Marcos DC on topic CiA402 framework for LinuxCNC (follow-up: runnable + simulation + easier debuggi
Some time ago I opened a topic about separating CiA402 logic from EtherCAT and validating it in a more modular way.
forum.linuxcnc.org/ethercat/58434-separa...ter-drive-stub-valid
Since then I kept working on that idea and turned it into something more complete that is now actually runnable and easier to test.
What problem I was trying to solve:
While studying and experimenting with CiA402 setups (and reading quite a few forum threads), I kept running into the same kind of issues:
often ending up debugging everything at once (motion + HAL + EtherCAT + drive)
not knowing if a problem comes from logic, wiring or hardware
drive-internal homing causing unexpected behavior or following errors
difficulty understanding what the controlword / statusword is really doing at runtime
So the goal here is not to replace anything, but to make those problems easier to isolate and understand.
What this does differently
The main idea is to separate things a bit more clearly:
keep LinuxCNC motion as-is
isolate CiA402 semantics (state machine, CSP, homing, etc.)
keep hardware/backend separate (EtherCAT, etc.)
This way it's possible to:
test CiA402 behavior without hardware first
see what's happening internally instead of guessing
debug logic without mixing it with transport issues
You can run it directly (no EtherCAT required):
git clone github.com/MarcosDuqueCesar/linuxcnc-cia402-layer
cd linuxcnc-cia402-layer
find comp -name "*.comp" -exec halcompile --install {} \;
linuxcnc ini/examples/runtime_validate_xyz.ini
scripts/diag.sh
This runs a full CiA402 pipeline using a stub backend.
You can observe things like:
controlword behavior
statusword transitions
mode switching (CSP / HOMING)
basic sequencing / watchdog behavior
Debugging focus:
One thing I tried to improve is visibility.
Instead of guessing, you can see internal state and get a better idea if the issue is:
logic / sequencing
HAL wiring
or backend / hardware
About homing:
This is one area that motivated the work.
In some setups, using drive-internal homing can lead to following errors if the LinuxCNC side is not kept consistent with what the drive is doing.
Here, homing is treated as a separate semantic part instead of being embedded inside the driver logic, so it's easier to observe and reason about.
Current status:
simulation: working
CiA402 logic: validated in runtime
hardware integration: not yet tested
This is intentional so far — the focus was to understand and validate the CiA402 behavior first without requiring hardware.
Scope:
This does not replace:
real-time tuning
EtherCAT setup complexity
Those are still necessary.
This is mainly about structuring and understanding CiA402 behavior.
Feedback:
If anyone is working with CiA402 in LinuxCNC, I’d really appreciate feedback.
Especially from real hardware setups, to validate the adapter/binding side.
scripts/diag.sh
Debugging focus:
logic / sequencing
HAL wiring
About homing:
Current status:
simulation: working
Scope:
real-time tuning
Feedback:
The following user(s) said Thank You: COFHAL, NWE
- NWE
- Thank you received: 87
30 Mar 2026 19:40 #344978
by NWE
Replied by NWE on topic CiA402 framework for LinuxCNC (follow-up: runnable + simulation + easier debuggi
Thanks!
I looked it over and tried the simulation. It's looking good. Later this week I hope to find time to try it on my hardware.
- Marcos DC
31 Mar 2026 00:18 #344983
by Marcos DC
Nice, thanks for testing it
And yeah, honestly you did a better job than the docs there
At that moment they were a bit messy and could easily lead in the wrong direction.
I just went through and cleaned them up properly (quick start is now simulation-first, no profile/topology needed, and observability is aligned with what diag actually shows).
So what you ran is basically the intended path, just not well explained before.
If you get time later to try it on real hardware, that would be really interesting to hear about.
Appreciate you taking the time to try it.
- Marcos DC
31 Mar 2026 03:11 #344987
by Marcos DC
Small update:
I aligned all docs with the actual runtime behavior and added a practical diag.sh guide.
Quick start is now simulation-first and profiles are clarified as declarative contracts.
Some parts were previously implicit (in my head), so this pass was mainly about making those assumptions explicit and removing ambiguity.
No changes in runtime/semantics — just making it easier to use and debug.
Now waiting for real hardware feedback.
- EtherCAT
Time to create page: 0.096 seconds
