Tuning Steperonline A6 Servos
6 months 1 week ago #345779 by andrax
Thanks for the help,
I'll go through this step by step and get back to you
6 months 1 week ago #345789 by ihavenofish
If all you did was autotune, you aren't done.
You need to set the feed forward. Also set the in position error allowance.
What could be happening is that 2 or 3 microns is still within the drives set error, so it just doesn't move.
5 months 2 weeks ago #346458 by Yippiekae
I'm at this step to. But I feel like it's been worse after the autotune than it was before.
That software is such a mess that I regret not going the Leadshine way.
I also have a slightly noisy Z axis servo but I can't find the gain parameter... Any clue ?
5 months 2 weeks ago #346464 by andrax
Oh, I almost forgot – I wanted to let you know if I succeed.I’ve been gradually increasing the C00.05 stiffness parameter.
4 months 1 week ago #347259 by StepperOnline
Please follow these steps for tuning:
1. Set C00.04=0 to switch to manual mode.
2. Confirm the inertia ratio (using the drive's automatic inertia identification function).
3. Fine-tune the speed loop (C01.01, C01.02):
Gradually increase C01.01 until slight noise or vibration occurs, then back it off by 15–20%;
Gradually decrease C01.02 to eliminate steady-state speed error, but do not set it too low, or low-speed creeping/oscillation may occur.
4. Fine-tune the position loop (C01.00):
Gradually increase the value to shorten positioning time and reduce tracking error; if overshoot occurs, back it off by 10–15%.
5. Acceleration feedforward + velocity feedforward.
6. Adjust friction compensation:
Measure the friction torque in both the forward and reverse directions separately, then input the values.
However, at the 0.001mm (1μm) level, mechanical factors often limit precision more than electrical parameters—such as leadscrew backlash, thermal expansion, structural rigidity, and uneven guideway friction. If the steady-state accuracy remains stuck at a certain value after manual fine-tuning, it is likely a mechanical bottleneck that cannot be resolved by gain adjustments.
The following user(s) said Thank You: andrax, NWE
4 months 1 week ago #347278 by andrax
Hi Stepperonline Thank you very much for the guide, and a warm welcome to the forum. I hope you’ll be able to help us with any questions we have on the forum.
The following user(s) said Thank You: StepperOnline
Time to create page: 0.076 seconds
