- Thank you received: 4153
Rod - I appreciate your suggestions, but we seem to be talking past each other.PRogress!
The vendor supplied XML can go in the bin with the rest of your windows stuff. its for twincat. So explained. I have never used this stuff.
Quickest way to test outputs is to hook up an output to coolant or mist so you can trigger with GUI or MDI command
Done, thank you.MODERATORS - please change title to: Stepperonline A6 Ethercat - Digital IO [SOLVED]
Great you worked it out. But normally, there will also be settings to tell the type of input. eg, GPIO, Max Limit, Min Limit, Estop (disable drive),
Did you work that out too? eg If you want to use as GPIO, you need to set the type to be GPIO for a specific pin for internnalhoming, you need to set homing.
