EtherCat with LinuxCNC using 3/3 4.4kw and 1.5kw servo motors all 3 phase
25 May 2026 15:27 #346607 by hughcustoms
Hi All hope everyone is good.
So I am considering going the LinuxCNC with EtherCat  route as opposed to a Inovance EtherCat Controller route.
So the Motors are as Follower
3 x 4.4KW Servo Motors from JSS Motor with a EtherCat Drivers  3phase Units
3 X 1.5KW Servo Motors from JSS Motors with EtherCat Drivers 3phase Units with Brake
Would like to know if it possible to configure LinuxCNC to work with these motors and drivers
I also have 12 Analog Inputs(Endstops proximity endstops)
Also have a 32Inch Touch Monitor
So first and foremost can I go the LinuxCNC route
what is  the best recommendations
25 May 2026 17:28 #346615 by andypugh
The controller doesn't care about the size of the motors, and there are many working EtherCAT systems out there running LinuxCNC.
You probably want to be running the master / dev version of LinuxCNC at the moment as there are various new features aimed at EtherCAT in there (for example the ability to run a initialisation step in the drivers as soon as realtime starts).
25 May 2026 21:40 #346623 by rodw
probably a Beckhof EK1100 and 2 x EL1008 will look after your inputs. you might need to add EL2008 for any outputs. an EL5151 if you need an encoder input for spindle
26 May 2026 07:26 #346659 by hughcustoms
Thank you so as for the spindle, i am actually not using a spindle head as the machine is a metal forming machine, so i have 2 Y axis Motors 4.4kw, 1x X axis 4.4kw, 1.5 Z Axis for pressure and the 2 1.5kw on the resistance table moving up and down in relation to Z movement,
Will Look into the the Beckof units
Time to create page: 0.200 seconds
