More advanced EtherCAT setup questions
5 days 9 minutes ago #350491 by mwc
Going back to setting drive parameters, is there anyway to set ModParam with the generic cia402 driver, by addressing the required register directly and not using a 'named' parameter?
I'm back working on this, and have got the drive digital inputs working, however I'm back at needing to set a drive parameter, so is the above possible, or will I have to write a driver?
4 days 15 hours ago #350505 by rodw
Generally, parameters are set in your xml file using SDO's/ I have found one device where it was more convenient to set these using ethercat upload and download commands outside of LinuxCNC
The following user(s) said Thank You: mwc
Time to create page: 0.331 seconds
