J1900 eglfs vs Xorg/glamor
  • tietouwa
  • tietouwa's Avatar Topic Author
  • New Member
  • New Member
01 Sep 2026 23:39 #349207 by tietouwa
J1900 eglfs vs Xorg/glamor was created by tietouwa
Title: Qt eglfs vs Xorg/glamor on Intel J1900 — 1 kHz EtherCAT jitter (not LinuxCNC, GPU/X data point)
Not a LinuxCNC install. Posting because this forum already tracks iGPU/X vs servo-thread latency, and we have before/after numbers on one box.
Hardware: Intel Celeron J1900 (Bay Trail HD 8086:0f31), Debian 13 PREEMPT_RT 6.12, IgH EtherCAT master, 1 kHz, two axes. HMI is a fullscreen Qt Quick app on the same machine. Isolated CPU3 for the RT loop.
Same load, same kernel.
Xorg + glamor + x11vnc:
- P99 |jitter| about 52 us (after removing a measurement bias)
- worst -171 / +58 us
- many outliers; 60-90 points >=80 us per 5 s capture
Qt eglfs / eglfs_kms (no LightDM, no X, no VNC), QT_QPA_EGLFS_NO_LIBINPUT=1:
- P99 |jitter| 14 us
- worst -38 / +45 us
- 0 points >=50 us in ~35k cycles
A separate bug was measuring jitter mid-axis instead of wake-to-wake; that only moved the mean onto 0 us. The spike cleanup is the display path: X/glamor/x11vnc fighting i915 while the RT thread is on the sibling core.
We are not recommending this on Elkhart Lake (J6412/J6413). There, glamor already gave 100-300 us spikes; eglfs would own the GPU even harder.
Happy to hear if anyone running a Qt or other GL HMI beside a 1 ms servo thread has compared eglfs/KMS to a compositing X session.
02 Sep 2026 03:05 #349210 by rodw
Replied by rodw on topic J1900 eglfs vs Xorg/glamor
The Baytrail J1800-J1900's are a mess. Maybe its been fixed, but incorrect power management caused them to report they were overheating and shut down, I had a couple that went in the bin.
  • tietouwa
  • New Member
  • New Member
02 Sep 2026 03:25 #349211 by tietouwa
Replied by tietouwa on topic J1900 eglfs vs Xorg/glamor
Is simply improving heat dissipation enough, or are there other solutions? The N100 is too expensive.
02 Sep 2026 22:07 #349257 by rodw
No it was a fault in the kernel. There is nothing wrong with a J1900, I used one for years, its just the baytrail chipset.
The following user(s) said Thank You: tietouwa
Time to create page: 0.218 seconds
