J1900 L2 sibling: pin Qt HMI to CPUs 0-1, keep the 1 ms EtherCAT thread on CPU3
  • tietouwa
  • tietouwa's Avatar Topic Author
  • New Member
  • New Member
15 Sep 2026 21:27 #349668 by tietouwa
Not a LinuxCNC install. Same class of box as the earlier J1900 eglfs vs Xorg thread.Posting because the useful knob was not another kernel cmdline flag.
Intel Celeron J1900 has 2 MiB L2 as two 1 MiB slices:
CPUs 0-1 share one L2
CPUs 2-3 share the other L2
We already isolated the EtherCAT loop on CPU3 (SCHED_FIFO 80, 1 kHz).
That is not enough if the fullscreen Qt/eglfs HMI is still allowed on CPU2.
The UI then sits on the L2 sibling of the RT core and contends for the same 1 MiB.
Change (HMI only, not a whole-system cgroup):
before: Qt main / touch / QML / render / GPU worker allowed on CPUs 0-2
after: those threads allowed on CPUs 0-1 only
RT thread stayed on CPU3 both times
Same binary, same recipe, same 1 ms period, 20 automatic press cycles each side.
Jitter = wake-to-wake CLOCK_MONOTONIC minus 1 ms, integer microseconds.
0 us means |error| < 1 us. This is period error, not latency-test / cyclictest.
All numbers below are the full captures (approach + press + retract), not a PID subset.
Absolute jitter, nearest-rank, all samples
UI on 0-2 (20 runs) UI on 0-1 (20 runs)
n 119159 119254
P50 0 us 0 us
P95 6 us 1 us
P99 13 us 1 us
P99.9 21 us 2 us
signed min/max -42 / +46 us -13 / +14 us
|j| >= 10 us 2983 8
|j| >= 20 us 198 0
|j| >= 30 us 22 0
|j|
Per-run P50 / P95 / P99 / P99.9 (|jitter|, us)
# UI 0-2 UI 0-1
1 1 / 9 / 14 / 23 0 / 1 / 1 / 2
2 0 / 2 / 9 / 19 0 / 1 / 1 / 2
3 0 / 5 / 12 / 21 0 / 1 / 1 / 2
4 0 / 6 / 15 / 20 0 / 1 / 1 / 2
5 0 / 7 / 15 / 20 0 / 1 / 1 / 2
6 0 / 1 / 1 / 2 0 / 1 / 1 / 2
7 0 / 6 / 14 / 20 0 / 1 / 1 / 2
8 0 / 7 / 15 / 20 0 / 1 / 1 / 2
9 0 / 4 / 13 / 19 0 / 1 / 1 / 2
10 0 / 6 / 16 / 26 0 / 1 / 1 / 2
11 0 / 3 / 11 / 22 0 / 1 / 1 / 3
12 1 / 9 / 15 / 23 0 / 1 / 1 / 2
13 1 / 9 / 14 / 26 0 / 1 / 1 / 2
14 1 / 9 / 15 / 32 0 / 1 / 1 / 2
15 0 / 8 / 14 / 19 0 / 1 / 1 / 2
16 1 / 9 / 14 / 26 0 / 1 / 1 / 2
17 0 / 1 / 6 / 13 0 / 1 / 1 / 2
18 0 / 6 / 13 / 19 0 / 1 / 1 / 2
19 0 / 1 / 5 / 15 0 / 1 / 1 / 2
20 0 / 1 / 1 / 2 0 / 1 / 1 / 2
After the pin, every run has P99 = 1 us. 15/20 runs have max |j|
The 8 remaining >=10 us samples are two ticks each in runs 1, 8, 15, 16.
Point of the numbers
- P50 was already 0 us. The HMI was not ruining the median.
- The L2 sibling shows up in the tail: P95 6->1, P99 13->1, P99.9 21->2.
- Moving i915 IRQ off CPU2 was not sufficient by itself. User-space Qt
render can still land on CPU2 and thrash the RT core's L2.
- Do not set a cgroup AllowedCPUs=0-1 on the whole process: the FIFO
thread must still be able to bind to CPU3.
- Do not park every system thread on 0-1. This was only the HMI/render path.
Box (for context, not the variable under test)
- Debian 13 PREEMPT_RT 6.12, Qt eglfs_kms, no X
- IgH EtherCAT, 1 kHz, Lost frames = 0
- isolcpus / rcu_nocbs on CPU3, i915 IRQ on CPU0
Happy to hear if anyone running a GL HMI on Bay Trail saw the same
CPU2/CPU3 L2 pairing.
The following user(s) said Thank You: NWE
17 Sep 2026 01:41 #349693 by rodw
Well you got further than me years ago, you were able to boot the Baytrail PC (but mine was a J1850).
Isolating the sibling core is recommended. If you are using a NIC with an RT app that uses networking, its recommended to pin the NIC IRQ to the same core as the RT thread. Latency may be worse  but the network latency becomes the bottleneck. I could not see what you were pinning.
The following user(s) said Thank You: tietouwa
  • tietouwa
  • New Member
  • New Member
25 Sep 2026 08:48 #349866 by tietouwa
Thanks rodw. I'm not using ec_generic. The EtherCAT port runs on IgH's native ec_r8169 driver, which is polled from the RT thread on CPU3, so there is no NIC IRQ to pin. What I pinned: the 1 ms thread on CPU3 (SCHED_FIFO 80), and the Qt HMI threads on CPUs 0-1 via taskset. Isolating CPU2 is a good idea. I'll try it next.
  • tietouwa
  • New Member
  • New Member
19 Oct 2026 01:44 #350331 by tietouwa
Follow-up: isolated CPU2 as well.
HMI still on CPUs 0-1. EtherCAT thread still on CPU3, SCHED_FIFO 80.
isolcpus=managed_irq,domain,2,3 and irqaffinity=0-1, so the i915 IRQ
is off the L2 sibling. ec_r8169 is polled from that thread, no NIC IRQ.
These runs are 2 kHz (0.5 ms), not the 1 ms set above.
Same measurement: wake-to-wake minus the period, full capture,
absolute jitter, nearest-rank.
CPU3 isolated only, just before (10 runs, 124447 samples):
P95/P99/P99.9 = 4/5/7 us, max 15 us.
CPU2 isolated too (20 runs, 241941 samples):
P50/P95/P99/P99.9 = 0/1/1/2 us, signed -11/+12 us.
Every run has P99 = 1 us. |j| >= 10 us is 11 samples, |j| >= 20 us is 0.
Lost frames = 0, no missed cycles.
Time to create page: 0.251 seconds
