No output from lcec_configgen?
  • mwc
  • Premium Member
  • Premium Member
26 Oct 2026 17:06 #350470 by mwc
No output from lcec_configgen? was created by mwc
I've trying to create the XML for a Amsamotion EC1A-1016R-AM6 module, but lcec_configgen appears to be doing nothing.
The command appears to be recognised, but gives no output.
ethercat slaves shows my Lichuan CL3-E57H drives and the EC1A-Core, with -v option showing all the expected values, but lcec_configgen appears to do nothing. The terminal simply goes back to the prompt with no output.
This is on 2.9.10.
Anybody have any suggestions?
  • mwc
  • Premium Member
  • Premium Member
26 Oct 2026 17:57 #350471 by mwc
Replied by mwc on topic No output from lcec_configgen?
Quick update.
After some suggestions from ChatGPT, lcec_configgen worked by using the full /usr/bin/lcec_configgen command.
The resultant XML doesn't work, but it's given me a starting point which I can work with.
Time to create page: 0.073 seconds
