cia402.comp - can't compile in 2.10-pre2
27 Oct 2026 13:57 #350490 by tuxcnc
I am using a file from github.com/rodw-au/cia402_homecomp/blob/main/cia402.comp.
It has always compiled successfully for me in the past, and it has nothing to do with the internal homing routines of the drives.
I am attempting to transition from LinuxCNC 2.10-pre1 to 2.10-pre2.
I have managed to resolve a few issues, but I have no idea why `cia402.comp` refuses to compile.
The full output is:
root@HP-15:~/Pobrane# halcompile --install cia402.comp
cia402.comp:97: Warning: Old type 'unsigned' was replaced by 'ui32', but you should be upgrading to 'uint'.
cia402.comp:98: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:99: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:100: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:102: Warning: Old type 'unsigned' was replaced by 'ui32', but you should be upgrading to 'uint'.
cia402.comp:103: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:104: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:105: Warning: Old type 'signed' was replaced by 'si32', but you should be upgrading to 'sint'.
cia402.comp:108: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:109: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:110: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:112: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:113: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:114: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:117: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:118: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:119: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:121: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:122: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:123: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:124: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:125: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:126: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:127: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:128: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:129: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:130: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:131: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:132: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:133: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:134: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:136: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:139: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:140: Warning: Old type 'float' has been replaced by 'real'
cia402.comp:141: Warning: Old type 'bit' has been replaced by 'bool'
cia402.comp:142: Warning: Old type 'bit' has been replaced by 'bool'
Compiling realtime cia402.c
cia402.comp: In function ‘extra_setup’:
cia402.comp:173:13: error: lvalue required as left operand of assignment
cia402.comp:176:14: error: lvalue required as left operand of assignment
cia402.comp:179:20: error: lvalue required as left operand of assignment
cia402.comp:180:12: error: lvalue required as left operand of assignment
cia402.c:313:86: warning: unused parameter ‘prefix’ [-Wunused-parameter]
  313 | #define EXTRA_SETUP() static int extra_setup(struct __comp_state *__comp_inst, char *prefix, long extra_arg)
cia402.comp:171:1: note: in expansion of macro ‘EXTRA_SETUP’
cia402.c:313:99: warning: unused parameter ‘extra_arg’ [-Wunused-parameter]
cia402.comp: At top level:
cia402.comp:185:19: error: unknown type name ‘hal_float_t’; did you mean ‘hal_port_t’?
cia402.comp: In function ‘read_all’:
cia402.comp:203:3: error: implicit declaration of function ‘check_scales’ [-Wimplicit-function-declaration]
cia402.comp:203:16: error: lvalue required as unary ‘&’ operand
cia402.comp:204:16: error: lvalue required as unary ‘&’ operand
cia402.comp:207:10: error: lvalue required as left operand of assignment
cia402.comp:210:15: error: lvalue required as left operand of assignment
cia402.comp:213:18: error: lvalue required as left operand of assignment
cia402.comp:214:17: error: lvalue required as left operand of assignment
cia402.comp:215:26: error: lvalue required as left operand of assignment
cia402.comp:216:26: error: lvalue required as left operand of assignment
cia402.comp:219:26: error: lvalue required as left operand of assignment
cia402.comp:220:26: error: lvalue required as left operand of assignment
cia402.comp:221:26: error: lvalue required as left operand of assignment
cia402.comp:222:26: error: lvalue required as left operand of assignment
cia402.comp:223:26: error: lvalue required as left operand of assignment
cia402.comp:224:26: error: lvalue required as left operand of assignment
cia402.comp:225:26: error: lvalue required as left operand of assignment
cia402.comp:226:26: error: lvalue required as left operand of assignment
cia402.comp:227:26: error: lvalue required as left operand of assignment
cia402.comp:230:25: error: lvalue required as left operand of assignment
cia402.comp:232:27: error: lvalue required as left operand of assignment
cia402.comp:239:18: error: lvalue required as left operand of assignment
cia402.comp:240:19: error: lvalue required as left operand of assignment
cia402.comp:246:15: error: lvalue required as left operand of assignment
cia402.comp:248:15: error: lvalue required as left operand of assignment
cia402.comp: In function ‘write_all’:
cia402.comp:266:15: error: lvalue required as left operand of assignment
cia402.comp:268:10: error: lvalue required as left operand of assignment
cia402.comp:270:19: error: lvalue required as left operand of assignment
cia402.comp:274:19: error: lvalue required as left operand of assignment
cia402.comp:278:19: error: lvalue required as left operand of assignment
cia402.comp:280:21: error: lvalue required as left operand of assignment
cia402.comp:282:23: error: lvalue required as left operand of assignment
cia402.comp:289:23: error: lvalue required as left operand of assignment
cia402.comp:291:23: error: lvalue required as left operand of assignment
cia402.comp:295:10: error: lvalue required as left operand of assignment
cia402.comp:302:12: error: lvalue required as left operand of assignment
cia402.comp:306:12: error: lvalue required as left operand of assignment
cia402.comp:310:12: error: lvalue required as left operand of assignment
cia402.comp:313:19: error: lvalue required as left operand of assignment
cia402.c:311:80: warning: unused parameter ‘period’ [-Wunused-parameter]
  311 | #define FUNCTION(name) static void name(struct __comp_state *__comp_inst, long period)
cia402.comp:252:1: note: in expansion of macro ‘FUNCTION’
make: *** [/usr/share/linuxcnc/Makefile.modinc:117: cia402.o] Błąd 1
The initial lines regarding the replacement of old variable types with new ones seem fine, but the parts referring to lines 139 and 140 of the `cia402.comp` file look suspicious to me.
It appears that the declarations on lines 139 and 140 are incorrect; this is likely the source of all those error messages stating that a floating-point constant cannot be assigned to variables whose types the compiler fails to recognize.
I could be wrong, but I don’t see any other likely culprits.
Additionally, there might be a type conflict further down in the code, as `hal_real` in C corresponds to `double` rather than `float`.
In any case, this problem is beyond my capabilities, and without `CIA402.so`, my machine simply won't work...
  • grandixximo
  • grandixximo's Avatar
  • Platinum Member
  • Platinum Member
28 Oct 2026 01:10 #350501 by grandixximo
Replied by grandixximo on topic cia402.comp - can't compile in 2.10-pre2
a compatible cia402 is released with the latest linuxcnc-ethercat you don't need to compile it yourself, I also rewritten it in C.
github.com/linuxcnc-ethercat/linuxcnc-et...releases/tag/v1.47.0
here is the fixed component in C if you want to take a look
github.com/linuxcnc-ethercat/linuxcnc-et.../master/src/cia402.c
The following user(s) said Thank You: tuxcnc
28 Oct 2026 02:03 #350506 by rodw
Replied by rodw on topic cia402.comp - can't compile in 2.10-pre2
Great work. I assume this is only for 2.10 or does it also work for 2.9?
Also, Dominic's original component did not support homing with switches attached to the drive (just encoders). Has this component included limit switch homing support (probably linking to a homecomp)
  • grandixximo
  • Platinum Member
  • Platinum Member
28 Oct 2026 02:17 - 28 Oct 2026 02:18 #350508 by grandixximo
Both LinuxCNC 2.9.x and 2.10 are supported. The v1.47.0 release provides plain packages for 2.9.x and +getset packages for 2.10.0~pre2 and later. The component uses a compatibility layer for the old and new HAL APIs, while keeping the original pin and parameter names, so existing loadrt cia402 ... configurations should carry over.
On homing: your custom homecomp handles LinuxCNC-side homing integration and is not part of CiA 402, so it remains separate from the generic cia402 component. This release only ports Dominik's component to C. It still triggers and monitors drive-internal homing; the selected CiA 402 homing method, including methods using switches connected to the drive, is configured in the drive. No homecomp functionality has been added.
Last edit: 28 Oct 2026 02:18 by grandixximo.
28 Oct 2026 11:57 #350513 by tuxcnc
Replied by tuxcnc on topic cia402.comp - can't compile in 2.10-pre2
I couldn't have known about this, as I didn't examine the source files; I simply used the pre-built package you provided a link to. It doesn't work and instead throws the following error:
lcec_conf: /lib/x86_64-linux-gnu/libethercat.so.1: version `LIBETHERCAT_1.6.13' not found (required by lcec_conf)
The `libethercat_1.6.13.g61cc654-1+41.1_amd64.deb` package contains a file named `libethercat.so.1.2.0`, which includes the strings `LIBETHERCAT_1.6` rather than `LIBETHERCAT_1.6.13`—this is likely the cause of the error.
On the other hand, `linuxcnc-ethercat_1.45.0+getset-1+deb12u1_amd64.deb` works, but it does not contain `cia402.so`.
Consequently, I installed version 1.45 and used the `cia402.so` file extracted from the 1.47 package.
The machine works now.
Thank for your works.
File Name: cia402.so.tar
File Size:30 KB
  • grandixximo
  • Platinum Member
  • Platinum Member
28 Oct 2026 22:15 - 28 Oct 2026 23:16 #350524 by grandixximo
I will make a new release where I have a runtime check for the new symbols I added in ethercat, it's because I have been working on a seperate ethercat branch, with improvements on connectivity time, if you are interested is here
github.com/linuxcnc-ethercat/ethercat
you can also get updates if you install the repo here
github.com/linuxcnc-ethercat/apt
I will work on maintaining compatibility with vanilla ethercat, won't force users to use my ethercat, although IMO it is better :-)
Edit:
Uploaded here, this should work with your ethercat as well
github.com/linuxcnc-ethercat/linuxcnc-et...ases#release-v1.48.0
Last edit: 28 Oct 2026 23:16 by grandixximo.
29 Oct 2026 00:08 #350525 by rodw
So long since I've looked at this but from memory, Dominic's original component was built were he had a drive that homed to index. When I first tried to use it, before the homecomp was devised by Dewey Garrett, we found it needed to set pos_fb = pos_cmd while internal homing  to prevent following errors if using home switches attached to the drive. This was seperate to the homecomp but its still necessary.
In my homecomp, I have this comment
// RODW - the cia402 comp sets pos_fb = pos_cmd while internal homing to prevent following errors. This could be done here.
github.com/rodw-au/cia402_homecomp/blob/...2_homecomp.comp#L229
So not sure if its covered in Dominic's cia402.comp that you used as a base but I think it should be covered if this becomes an official comp in your ethercat repo.
Time to create page: 0.340 seconds
