Flex GUI 2.1.0 OpenGL 3.3
1 month 1 week ago #349883 by JT
Replied by JT on topic Flex GUI 2.1.0 OpenGL 3.3
So to get back on the subject of Flex GUI it is the only GUI that is very flexible and requires no programming to create the exact GUI "you" want without knowing anything about programming. If you just have one axis that's not a problem, Flex GUI can be as simple or as complex as you want. No other GUI is easy to change the look and feel and function for a non programmer.
JT
1 month 1 week ago - 1 month 1 week ago #349884 by JT
And actually if you thing about it Flex GUI "is" a plugin for LinuxCNC.
You install Flex GUI using your favorite method apt, gdebi or command line and set the DISPLAY = flexgui it can't get much simpler than that.
JT
Last edit: 1 month 1 week ago by JT.
Moderators: JT
Time to create page: 0.098 seconds
