Checking hal pin from NGC?
- machete
18 Sep 2013 00:21 #38950
by machete
Checking hal pin from NGC? was created by machete
Hello!
I am trying to folow this example, from here:
www.linuxcnc.org/docs/devel/html/remap/structure.html
But with any hal-pin it always show me "does not exist", or if i just try to debug it's value "######".
My version of LinuxCNC: 2.6.0
P.S. I want to have ability to do, or not to do part of NGC program (tool changing) depending on output pin of Classic Ladder.
o100 if [EXISTS[#<_hal[motion-controller.time]>]]
(debug, [motion-controller.time] exists: #<_hal[motion-controller.time]>)
o100 else
(debug, [motion-controller.time] does not exist)
o100 endif
- Thank you received: 5013
18 Sep 2013 06:35 #38964
You need to turn on the feature of reading HAL pins from g-code:
www.linuxcnc.org/docs/devel/html/remap/s...d_sub_ini_features_a
Replied by andypugh on topic Checking hal pin from NGC?
- machete
18 Sep 2013 14:50 - 18 Sep 2013 14:50 #38976
by machete
Replied by machete on topic Checking hal pin from NGC?
Thank you!
Is that correct?
[RS274NGC]
FEATURES = 8
enable #<_hal[Hal item]> readonly variables: 8
if set, the interpreter will fetch read-only values from HAL file through this special variable syntax.
Is that correct?
[RS274NGC]
FEATURES = 8
Last edit: 18 Sep 2013 14:50 by machete.
18 Sep 2013 17:03 #38980
Yes, though you might want to use FEATURES=12 to get access to INI file parameters too.
Is that correct?
[RS274NGC]
FEATURES = 8
- machete
25 Sep 2013 21:02 #39181
by machete
Hmm... i wasn't able to get any #<_hal[hal-pin]> value before executing M66 g-code!
(i spent two days to understand that)
So, here is my correctly working NGC program for tool changing:
o<mytoolchange> sub
M66 P3 L0 Q0 (asking Classic Ladder is tool change needed?)
(flag from classic ladder)
(#debug, [5399]: #5399 - showing OK!)
(#debug, [skip-tool-change]: #<_hal[skip-tool-change]> - also showing OK!)
o100 if [#5399]
(debug, Skip changing tool!)
M6 (just legalize it for system)
o100 else
(debug, Changing.)
M5 (stop spindle)
G0 G53 Z75.1 (go to plane of Tool Magazine's clamps)
M64 P0 (enabling DO-CHANGE bit for classic ladder)
M66 P0 L3 Q2678400 (waiting 1 month for PHASE2 signal when)
G0 G53 Z205.3 (go back to left tool in the clamp)
M66 P1 L3 Q2678400 (waiting 1 month for PHASE3 signal)
G0 G53 Z75.1 (go to plane of Tool Magazine's clamps Y75.5)
M66 P2 L3 Q2678400 (waiting 1 month for CHANGED)
M65 P0 (disabling DO-CHANGE bit)
M6 (acting loopbacks)
o100 endif
o<mytoolchange> endsub
M2
Time to create page: 0.182 seconds
