Parallel Port Tester
- BigJohnT
- Thank you received: 994
To run this place both files in the same directory and open a terminal window and use the command
halrun -I -f ptest.halYou can push the output buttons and change the state of each output. When you toggle an input it shows up on the screen.
Attachment ptest.zip not found
Enjoy
- TarHeelTom
This is a little parallel port tester done with pyVCP.
<snip>
Enjoy
John,
What is the switch immediately following "halrun" in the above code sequence?
Tom
- BigJohnT
- TarHeelTom
- Tonico
When I run halrun -I -f ptest.hal I get " Waiting for component 'PortTest' to become ready" a bunch of dots and than halcmd: I also get a new blank window called PortTest., eventually every thing seems to time out and I get back the normal prompt and the blank window closes.
This may wll be something that I am doing wrong due to my ignorance of Linux.
Any help wpould be appreciated
TIA
Tony.
- Thank you received: 1481
I would use it (a slightly modified version) to test if certain ports would work work in X-mode. I would start the test then probe holes with a resistor to see if the circles changed color.
- Tonico
Is there anything that I need to do or set up BEFORE I run the test?
TIA
Tony
- BigJohnT
It should just work...
Are both files in the same directory?
Did you open the files with a windoze editor that might have tacked on some funny stuff to the end of each line?
- Tonico
Yes both files in the same directory
Downloaded directly to the Linux box and used "text editor" to verify the port address.
Tony
