XHC-HB04 wireless MPG pendant HAL module
  • f1oat
  • f1oat's Avatar Topic Author
  • Junior Member
  • Junior Member
20 Jun 2013 05:30 #35818 by f1oat
Here is a first release of my HAL module to use the XHC-HB04 MPG pendant with LInuxCNC.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
Hope that helps other users :)
Frederic.
The following user(s) said Thank You: tommy, akb1212, bottleworks
20 Jun 2013 15:26 #35832 by bigalex
Replied by bigalex on topic XHC-HB04 wireless MPG pendant HAL module
Hi Frederic.
First of all congratulations for your work and for sharing your knowledge with us . :)
Is the display working and the screens layout programmable ?
bigalex :blink:
  • f1oat
  • Junior Member
  • Junior Member
21 Jun 2013 01:01 #35845 by f1oat
Replied by f1oat on topic XHC-HB04 wireless MPG pendant HAL module
Yes, the LCD screen is managed as a DRO showing current position (X, Y, Z, A, spindle and feedrate).
But the layout cannot be modified because it is hard coded in the LCD matrix.
However, you can choose to display other float signasl than the standard machine and workpiece coordinates by patching the xhc-hb04.hal file.
Frederic.
  • f1oat
  • Junior Member
  • Junior Member
21 Jun 2013 02:20 #35846 by f1oat
I uploaded V02 to fix Makefile issue and LCD refresh.
21 Jun 2013 22:13 #35886 by bigalex
Hi Frederic.
Thanks again for your efforts .
Where did you bought the MPG ?
bigalex :blink:
  • f1oat
  • Junior Member
  • Junior Member
22 Jun 2013 03:49 #35902 by f1oat
I have bought the MPG from a local guy. Unfortunately there was only one unit.
I have added a picture in the wiki page.
Here we have one with same layout www.aliexpress.com/item/MACH3-WIFI-mpg-U...ldbus/639910195.html but it seems out of stock
Similar devices are common on ebay, but with few modifications on the keyboard layout.
I assume we will have to adapt the HAL source code to accommodate other layouts. I can do that for you.
Frederic.
22 Jun 2013 14:05 #35909 by bigalex
Hi Frederic.
Thanks for your kind offer .
I will try to find one like yours hopefully at a good price. ;)
Regards
bigalex :blink:
23 Jun 2013 01:40 #35926 by tommy
Replied by tommy on topic XHC-HB04 wireless MPG pendant HAL module
Thank you for your effort!
Now, I'm already interested to purchase one, and just want to make sure, that this one will be compatible with your hal, except some minor modifications considering key layout?
www.ebay.com/itm/New-Wireless-MPG-Pendan...&hash=item2ec8b6694a
  • f1oat
  • Junior Member
  • Junior Member
23 Jun 2013 04:58 #35930 by f1oat
@tommy this MPG looks very similar to mines, except the names of buttons.
If the USB protocol is the same, the keyboard layout adaptation should be easy.
It will require some modifications in the C source code that I can do.
I will say that we have 90% of chance that the adaptation will be easy to do.
Frederic.
23 Jun 2013 06:54 #35931 by tommy
So if I want to go with 100% easy, I shold go with this one, which seems to be the same as yours:
www.ebay.com/itm/Wireless-Handwheel-USB-...&hash=item27d04a2425
Time to create page: 0.311 seconds
